Speaker Connects
Old Aug 10, 2007 | 07:42 PM
CoolRedXylophone's Avatar
Default Speaker Connects
How important are ring terminals, spade, female, ect. connectors when it comes to hooking up my speaker wire to my amp and speakers. Do i need to find some high quality ones or will standard ones be just the same?
thanks
Old Aug 10, 2007 | 08:34 PM
fcm's Avatar
fcm
Old Fart
Default Re: Speaker Connects (CoolRedXylophone)
A good quality, "ordinary" connector from someone like PICO will do just fine, more often then not, it is better quality then that "gold" stuff you pay an arm and a leg for, [there is not enough gold in them to short circuit the dynamo on a firefly's ***].
The trick with connectors is to have the right one for the connection you are making, both in type and wire/stud size and solder it to the wire/cable. 94
Old Aug 11, 2007 | 03:56 AM
TEGNO1's Avatar
Try and use the the least amount as possible just connect wires straight to an amp as any added connecter adds resistance but things like earth connections to chassis might not be possible.
dem0nk1d
Audio / Security / Video
Feb 11, 2011 05:37 AM
gunsnbam
Feb 14, 2010 08:15 AM
CivicSi95
Feb 10, 2009 08:43 AM
shabasoft
Aug 31, 2004 08:20 AM
tub_sephiroth
Mar 27, 2004 09:07 AM
