sparco...
Old Jun 20, 2003 | 03:05 PM
jsmurfy's Avatar
Default sparco...
sup everyone, i was thinking about putting some sparco harnesses in my car but i dont know if i should chose the snap in mounting or bolt in mounting. im just using them for the streets. also which ever one i chose, do i need to bget seats as well, or can i use the factory ones? thanks
peace
Old Jun 20, 2003 | 09:25 PM
creasian's Avatar
Default Re: sparco... (jsmurfy)
just keep in mind, harness can be very dangerous if you dont have a roll cage.
Old Jun 20, 2003 | 09:51 PM
jsmurfy's Avatar
Default Re: sparco... (creasian)
care to educate me please
Old Jun 21, 2003 | 07:03 AM
rjr162's Avatar
you can use the stock seats, but they fit better if you have racing seats of course. Just remember to use stock reinforced parts (IE> the bolts and holes where the factory belts bolt. you have the front section of harness (the part that holds you) to be as vertical as possible, and the rear section (the point after it crosses the seat) to be as flat as possible. The best area for this is if you have a cage or something and can run the lines straight back to a mounting point. If you don't, use the bolts and holes for the rear seat belt lap areas.
Old Jun 21, 2003 | 07:44 AM
jsmurfy's Avatar
Default Re: sparco... (rjr162)
thanks
malubawla
Mar 1, 2006 04:24 PM
Slow Egg
Nov 15, 2002 11:00 AM
xXx Justin xXx
Sep 13, 2002 03:54 AM
MintyDip
36
Jul 13, 2002 11:48 AM
