Soo Much NOISE!!
Old Feb 23, 2005 | 09:36 PM
LaOstha's Avatar
Default Soo Much NOISE!!
I have a 92 ferio with pioneer head unit and jl componet speakers and a 10" mtx sub and amp. The other day i go to change out the amp for a bigger one and when i turned the system back on the amped fried. Now i put in the old amp and now theres so much engine noise its unbearable.. I check all the fuses and my grounds. they are all good. I dunno wut to do im a newb with car audio. Any and all help is great...thanks
Old Feb 24, 2005 | 05:07 PM
LaOstha's Avatar
Default Re: Soo Much NOISE!! (EggRollzEveryDay)
any one?? I cant drive wit no music
Old Feb 24, 2005 | 05:17 PM
shawn_crx's Avatar
is it the engine noise (alt)?
Just make sure your RCA Jack is not running close with the power wire.
Probably need to add a noise reductor.
Old Feb 24, 2005 | 08:49 PM
LaOstha's Avatar
Default Re: Soo Much NOISE!! (shawn_crx)
i went to the audio store to try a noise reducer and it didnt work. I could barely here anything
Old Feb 25, 2005 | 01:07 PM
shawn_crx's Avatar
Default Re: Soo Much NOISE!! (LaOstha)
sound like you got a short in your speaker wires/RCA Jack.
maybe hook up backward.
Old Feb 25, 2005 | 07:40 PM
drunknbass's Avatar
i read something somewhere about having multiple chassis grounds on a car. like say for instance a major one would be the ground off an amp, and another is the car battery, and when you have too many grounds connected to high voltage/demand things itll cause a circuit to form in the chassis. but im not a stereo guru, i just read that somewhere.
Old Feb 26, 2005 | 10:13 PM
RallyRedGT-V6's Avatar
Default Re: Soo Much NOISE!! (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">i read something somewhere about having multiple chassis grounds on a car. like say for instance a major one would be the ground off an amp, and another is the car battery, and when you have too many grounds connected to high voltage/demand things itll cause a circuit to form in the chassis. but im not a stereo guru, i just read that somewhere.
That is true, but only when you have 2 high amp units grounding very close to each other [like within a couple feet]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">sound like you got a short in your speaker wires/RCA Jack.
Polarity of RCA does not matter. ever. The amp just gets a backward signal, it doesn't know whats right and left, it just does what its told.
double check your ground.
Old Feb 27, 2005 | 08:43 AM
LaOstha's Avatar
Default Re: Soo Much NOISE!! (RallyRedGT-V6)
thanx everyone...I fucked around with my ground wire and it kinda sorta reduced the noise.... Whenever i tap the brake or when my lights are on or signals it gets worse
Old Mar 2, 2005 | 05:15 PM
89hbcivicguy's Avatar
throw the pioneer head unit in the garbage and buy a kenwoon that fixed my problem!
i had the exact same thing!
SoTexDC2
Audio / Security / Video
May 7, 2007 08:28 PM
jojo006
Sep 13, 2005 09:16 AM
lemongreenhatch
Jun 5, 2005 09:10 AM
King_j
Sep 25, 2003 12:34 PM
shattergsr
Jun 12, 2002 06:24 PM
