sony head unit issues
Soooo iv been having issues with my sony headunit....first it started that it would cut out and reset once in a while then it started happening more and last week it just shut off completley and didn't work at all it started working again and now it cuts out every time I brake....its getting annoying...any advice would be great
I'm running a sub and amp with stock door speakers if it maters
Thanks
Thanks
Check grounds, battery terminals. I have seen this happen when the output from the alternator is low. As in, VERY low. Check the voltage across the terminals, with headlights on and off. You see: braking turns on the brake light which, if you alternator is WEAK, will sap power away from the headunit. Same with headlights, obviously. Did you have similar problems with other headunits? Does it cut out when using other power functions (if you have them.)?
If it WERE an alternator issue, my bet is that the radio would not cut out if you hit the brakes while keeping the engine revving high. Same with the lights (I bet the radio starting working again as soon as you began driving.)
Also: check the radio fuse. Sometimes corrosion on fuse blades can cause voltage drop. Check your ground wire. How did you wire the radio in? If you used wire nuts or electrical tape, try re-doing it using crimp on barrell (butt) connectors.
Radio is done with connectors
Iv checked everything grounds and terminals I think I'm gonna pull out my alt and get it tested
I had another head unit a while ago and it didn't do it had the sony one for around a year and it just started doing it :/
Did you test voltage across terminals? I would do that before pulling the alt.
Am I right about it not cutting out at higher RPM?
And check the radio fuse for corrosion. You never know.
Fuse is fine first thing I checked
Yeah it only happens at low rpms
I don't have a multimeter so I can't test it :/
Alternator is only a year old :/
Unfortunately, the alt being only a year old works against you. I find alot of the time remanufactured (or aftermarket) alternators fail rather quickly. I personally would rather find a working one in a junkyard if that is an option. Also- check harborfreight for a multimeter. I got one there for ~3$ about 3 years ago and it still works great! I can't even tell you how many times it has saved my ***.
If you are not having problems starting the car, it is unlikely you are having problems with the alt., because problem started with HU losing power and "resetting" check the HUs 12V constant power fuse, almost always in engine bay fuse box and almost always a 7.5A marked "back up".94
structure1990
18
Jan 25, 2014 09:13 PM
crxaddikt
Jul 5, 2012 10:08 AM
EGmikeH22
Oct 4, 2005 06:43 AM
spicoli
10
Sep 22, 2004 05:45 PM
