Solo-Baric box dimensions??
I have 2 Solo-Baric 10L7's, and I want to build a box for them myself instead of having to buy one that probably isn't made for an L7, so I was just wondering if anyone has built their own box, and if so, what were the dimensions that you used to make your box? I pretty good at building things once I have dimensions. If you have the dimensions for "2" 10L7's, could you send them to me, plus pics would also be great....Also, these are going into a 2000 Prelude
Thanks
Thanks
You can go to kicker.com to get recommended air space . [volume] then as long as the volume is right ,you can build box to fit the lude.
hope this helps.
94
hope this helps.
94
baric, barics, box, build, demensions, dimension, dimensions, enclosure, measurements, perfect, solar, solo, solobaric, specs, sze
