Sealed or ported?
Old Apr 17, 2003 | 07:00 PM
dannyboi's Avatar
Default Sealed or ported?
What have you guys had better success with, sealed or ported box. I have a small sealed box right now but would like some low GHETTO bass, also more SPL. So I'm thinking of going with a ported box.
Old Apr 17, 2003 | 07:09 PM
99_BlackSI's Avatar
Default Re: Sealed or ported? (dannyboi)
Sealed = Tight, Clean Bass
Ported = SPL, and Low Bass
I think you know what to do now
Dave
Old Apr 17, 2003 | 08:01 PM
i's Avatar
i
i think jlaudio.com has a tutorial section that explains each type of box, how they work, pros and cons, and even how to build them (i think)
Old Apr 17, 2003 | 09:36 PM
t0p_sh0tta's Avatar
Default Re: Sealed or ported? (i)
What sub(s) do you have and what kind of power?
Old Apr 17, 2003 | 10:16 PM
rcurley55's Avatar
New User
Default Re: Sealed or ported? (t0p_sh0tta)
PORT THE IDQ's!!!!!!!!!
I don't understand why people don't port these woofers, not only do they go LOW, but they get pretty loud too.
Old Apr 17, 2003 | 10:25 PM
dannyboi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">What sub(s) do you have and what kind of power?</TD></TR></TABLE>
Image Dynamics 12" IDQ's, PPI amp, I can either do 600w x1 @4ohms or 300wx2 @2ohms.
I have them wired mono right now in a sealed box. They sound nice and tight but I have to turn the gain on my amp kind of high to get the "boom" I want. That causes my amp to warm up more than I would like it to. What do you guys think about those rear sealed band pass boxes.
Old Apr 17, 2003 | 10:53 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannyboi &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think about those rear sealed band pass boxes. </TD></TR></TABLE>
Check out my post above...trust me, I've had those woofers in both boxes, and the ported is the way to go!
Old Apr 18, 2003 | 01:08 AM
vteg's Avatar
New User
I personally avoid bandpass like the plague. Maybe one day I will hear one that I like.
Ports are your friend.
Old Apr 18, 2003 | 06:24 AM
JOMO
Guest
Posts: n/a
Default Re: Sealed or ported? (vteg)
* PORT ME, PORT ME PLEASE* thats your subs talkin mang
Old Apr 18, 2003 | 09:23 AM
arsenaldragster's Avatar
Default Re: Sealed or ported? (JOMO)
ported boxes
sealed enclosures
check the specs on those woofers.. they should have dimensions for both ported and sealed enclosures..
or be like me an go with a fiberglass floor box
Old Apr 18, 2003 | 04:16 PM
vteg's Avatar
New User
Default Re: Sealed or ported? (arsenaldragster)
If you want to try both, and the woofer can go 2 cubes ported, or sealed. You can build the box, port it. And listen to it ported, and with the port closed(sealed) to determine which you prefer.
Old Apr 18, 2003 | 04:50 PM
dannyboi's Avatar
Well I think I'm going to port them but I read on the web site to give each woofer 2.0 cubic feet w/ a 4"x14" port. However I called Image Dynamics and spoke with their tech support and he said to give them 1.25 to 1.5 each with 3"x14" port. Which should I build?
Old Apr 18, 2003 | 05:01 PM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannyboi &raquo;</TD></TR><TR><TD CLASS="quote">Well I think I'm going to port them but I read on the web site to give each woofer 2.0 cubic feet w/ a 4"x14" port. However I called Image Dynamics and spoke with their tech support and he said to give them 1.25 to 1.5 each with 3"x14" port. Which should I build? </TD></TR></TABLE>
If spoke with the guys at ID, listen to them. I dont' know where you got 2 cubes from their web site...maybe you were looking at old data from the original V1's?
I'd suggest a box that is 1.5 cubes gross, tuned to around 30Hz. I used 10 square inches of slot port on my box. I took my design from thier tech sheet:
http://www.imagedynamicsusa.co....html
But converted the round port to a slot port. You will find it terribly difficult to squeeze a port of that size into a box that small without getting the port tube too close to the walls of the enclosure. You will probably have to put a bend in the port or slot port it.
If you build this box right, you will love it....let me know if you would like me to check out your box design.
Old Apr 18, 2003 | 07:12 PM
dannyboi's Avatar
Default Re: Sealed or ported? (rcurley55)
I guess the smaller one is right? I don't know what the heck I printed up! Anyway these are my demensions, 16"h,14"d,30w, and 3"x14" port. what do you think?
Old Apr 18, 2003 | 07:20 PM
rcurley55's Avatar
New User
Two things:
1. are those your inside or outside dimensions - assuming that you are making a square box?
2. you need two ports...not one
Old Apr 18, 2003 | 07:38 PM
dannyboi's Avatar
Those are the out side demensions, and I meant two ports.
Old Apr 19, 2003 | 09:08 AM
rcurley55's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannyboi &raquo;</TD></TR><TR><TD CLASS="quote">Those are the out side demensions, and I meant two ports.</TD></TR></TABLE>
That will get you 2.9 cubes, which is the larger enclosure...make sure you brace that enclosure well.
Old Apr 19, 2003 | 09:56 AM
dannyboi's Avatar
How would I brace the box?
What kind of bass should I expect from this size box?
Old Apr 19, 2003 | 10:02 AM
rcurley55's Avatar
New User
REad this:
http://www.jlaudio.com/tutoria....html
You will get a strong low end, and really accurate bass. I have no clue what "ghetto" bass means....
Just make sure that if you go to a ported design, you don't go blaring a bunch of really low frequency stuff through it without a subsonic filter. Below the tuning frequency (you will be in the 28-30Hz range) the box is no longer able to help control the movement of the cone.....this can lead to lots of damage, so just be careful. You will have no problems with regular music, but a bass CD may creep up on you.
Old Apr 19, 2003 | 10:18 AM
dannyboi's Avatar
Thanks for the link. What about the ports, do they need to be facing the same direction as the woofers?
Old Apr 20, 2003 | 12:50 AM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">but a bass CD may creep up on you.</TD></TR></TABLE>
LOL
Old Apr 20, 2003 | 10:24 AM
dannyboi's Avatar
Well I just finished the box, threw it in and turned on my stereo.... but I heard no bass. Just as I started to freak out I remembered that I had turned the gain all the way down, at this point I had the volume pretty high, so when I turned it up DAAAAMN! I could believe how loud and deep they were playing. I doubt I will ever do a sealed box again, unless I have a huge class D amp. I just want to thank you guys for your help it was greatly appreciated. The only problem now is fighting the urge to play a bass CD
Old Apr 20, 2003 | 10:28 AM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannyboi &raquo;</TD></TR><TR><TD CLASS="quote">Well I just finished the box, threw it in and turned on my stereo.... but I heard no bass. Just as I started to freak out I remembered that I had turned the gain all the way down, at this point I had the volume pretty high, so when I turned it up DAAAAMN! </TD></TR></TABLE>
my reaction when i built my first ported box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
I could believe how loud and deep they were playing. I doubt I will ever do a sealed box again, unless I have a huge class D amp. </TD></TR></TABLE>
werd...i'm never going back to sealed (not that i ever did went sealed ) why wouldn't u port with a 'huge class D amp"?
I just want to thank you guys for your help it was greatly appreciated. The only problem now is fighting the urge to play a bass CD </TD></TR></TABLE>
no problem..
if you have kazaa..download some IASCA tracks or bass mechanic.
Old Apr 20, 2003 | 11:27 AM
vteg's Avatar
New User
Default Re: Sealed or ported? (GSteg)
My new sub is my first ported sub in a car.
I have had it running off 2 channels from my 300/4 for three weeks. I purchased a 1500dr yesterday. OMG. I think the hatch is going to jump off the car. My friend wanted to hear it when we were leaving an underground garage last night. A quick note set off half a dozen alarms
Now I have to tackle electrical problems. My lights will dim on the freeway , if I turn it up. Well all lights besides the HID's.
Old Apr 20, 2003 | 08:55 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannyboi &raquo;</TD></TR><TR><TD CLASS="quote">Well I just finished the box, threw it in and turned on my stereo.... but I heard no bass. Just as I started to freak out I remembered that I had turned the gain all the way down, at this point I had the volume pretty high, so when I turned it up DAAAAMN! I could believe how loud and deep they were playing. I doubt I will ever do a sealed box again, unless I have a huge class D amp. I just want to thank you guys for your help it was greatly appreciated. The only problem now is fighting the urge to play a bass CD </TD></TR></TABLE>
LOL..... is it at GHETTO bass now?
