recommendations on speaker/sub setup for 95 Prelude VTEC..?
Old Dec 9, 2001 | 12:11 PM
Mike95lude's Avatar
Default recommendations on speaker/sub setup for 95 Prelude VTEC..?
Ok...I have a new Alpine CDA-7875 headunit (awesome) but otherwise completely stock system. What should I do? I could do components in the front? I hear the door speakers can fit a 6.5, but its really tight. The rear also uses 6.5's doesn't it?
The dash stock has tweeter speakers where I could put the new tweeter in if I get components. I just want rich crisp sound. Then I want to put a sub(s) in the trunk after this.
Old Dec 10, 2001 | 04:49 PM
cam003's Avatar
Default Re: recommendations on speaker/sub setup for 95 Prelude VTEC..? (Mike95lude)
JL SUBS AND MB QUART HIGHS AND MIDS that all you need to know. all you stock location will work, and use the dase spot fopr the new tweets dont cut you doors, and you may need to get the mids in the doors done by a pro so he can create some depth for you its not a easy task. this set up is not cheap but it is your car and you only pay for it once.
[Modified by cam003, 1:50 AM 12/11/2001]
Sabotage
Jan 26, 2006 12:37 AM
tim5371
Aug 22, 2004 08:25 PM
PhilJ95GSR
Audio / Security / Video
Dec 28, 2001 04:04 AM
MRDC2
May 22, 2001 06:46 PM
