RCA output from headunit
Old Jun 12, 2014 | 07:55 PM
gizbirne's Avatar
Icon2 RCA output from headunit
Ok i now that im amplifing my speakers and i already got a sub amplified
is it better that i run 3 set of rca cable trhough the headunit to the sub amp, and front & rear to the speaker amp ?
or i can wire the rear and front speaker to the amp (2 long RCA to the headunit) and then use the output of speaker amp to my sub input RCA (with a 1 foot rca cable or w/e) !?
i got the pinoneer DEH-X8600BH
Thx
Old Jun 13, 2014 | 05:58 AM
grumblemarc's Avatar
The Grumpiest
Default Re: RCA output from headunit
Aren't you pretty much saying the same thing twice?
Old Jun 13, 2014 | 08:18 AM
NVturbo's Avatar
O.G. triple O.G.
Buy a quality 2-way crossover. Run one RCA (high/full-range) to the door speaker amp and one RCA (low/sub) to the sub amp. Problem fixed.
Old Jun 13, 2014 | 09:02 AM
gizbirne's Avatar
im new to the audio scene sry, why would i need a 2 way crossover ? i think my Headunit also has a crossover ...
headunit got 3 pre-amp (4v) output Front, Rear And SUB
can i run 2 RCA from front and rear to speaker amp THEN from the RCA output of the speaker amp to the RCA input of SUB amp ?
Old Jun 13, 2014 | 09:27 AM
The Grumpiest
RCA outs on an amplifier? Have there been advancements in amplifier technology that they are now manufactured with RCA outputs? The last amp I bought had RCA inputs only and those were from the RCA outputs of the headunit.
Specs say that your headunit has 3 sets of RCA preouts so, without checking, I'm going to assume they are front, rear (or left and right) and sub outputs. If that is correct then don't make it harder than it is.
Front and rear run to a 4 channel amp (or two separate amps from front/rear or left/right) and the sub outputs go to the sub amp.
Next time read up on how to hook these things up before you run out and buy them.
Old Jun 13, 2014 | 09:41 AM
gizbirne's Avatar
http://www.ebay.ca/itm/201091229216?...84.m1497.l2649
thats not 1 RCA output & 2 input ?
im reading atm and its on its way thx
i know i could run 3 LONG rca from the headunit to those amps but i want to save 1 long wire if possible...
Old Jun 13, 2014 | 09:45 AM
gizbirne's Avatar
i just thought maybe the headunit was sending a different signal for the sub woofer RCA output so maybe i cant wire my output speaker amp to subs amps
Old Jun 13, 2014 | 10:12 AM
gizbirne's Avatar
lol ive figured it out ! ill just use a 4 chan RCA cable :D
THX tho
Old Jun 13, 2014 | 10:20 AM
The Grumpiest
That's what I said.
Old Jun 13, 2014 | 10:51 AM
gizbirne's Avatar
To me that doesnt mean use a 4 chan RCA cable...
and at that post time i didnt know before more research that a 4 chan RCA cable existed >_<
Anyway thx a bunch
Old Jun 13, 2014 | 05:37 PM
TunerN00b's Avatar
Um, car amps have had RCA outputs for a very long time. They're used for daisy chaining amplifiers. You end up going headunit -> RCA -> amp -> RCA -> amp -> speaker wire -> speaker.
Not all amplifiers have this feature. Just like not all of them can bridge a channel, or include a crossover, etc...
Anyway thx a bunch
A 4 channel cable, a pair of 2 channel cables and a twist tie, same thing.
If you're really feeling cheap, and aren't pushing excessive power, just use an old component video cable with audio. That's a 5 channel RCA cable that no one knows what to do with these days since HDMI is so much more compact and easier.
Old Jun 13, 2014 | 06:58 PM
The Grumpiest
Um. I said it's been awhile. And the only ones I ever messed with didn't have them. I can show you a pic of the one in the car now.
Cody2289
Audio / Security / Video
14
Feb 11, 2008 09:28 AM
iBrandon
11
Nov 29, 2006 04:40 PM
Torridcivic
Sep 23, 2003 07:49 PM
schwinn
Jun 19, 2002 10:54 PM
juniordc2
12
Jun 4, 2002 11:07 PM
