rate my system
Old May 4, 2010 | 10:18 AM
f22a1 ftw's Avatar
Default rate my system
i know not alot of you like loud audio systems but there has to be some so if u want to rate mysystem ur welcome to it even negative comments are welcome also if u have a system put what u got(only made this out of pure boredom)
-jvc kd-r618 headunit
-kenwood KAC-720 2 channel amp(1000w peak about 250x2 rms)
- dual jl audio 12w0
-dual chamber nonported box(ground shaker box)
-Rockford fosgate amp wiring kit
-audiobahn captor
-components pioneer 3.5sor 4.5inch bought them along them about 5 or 6 weeks ago forget model number
-dynamat on both doors and in the trunk and also on the back on the plate above the rear seats
where the factor speakers
-jvc KT-HD300 hd radio adapoter
-4 guage power and ground wire
-8gauge speaker wire for the subs facotor w/e gauge for componentsits facotor with the little wire they come with
-and like 12 guage for the remote wire(hooked up to the battery then though a toggle switch so if i dont want the bass i can just switch the amp off)
-license plate reduced rattle kit
(i think i may of forgot somthing but thats verything orignaly i just posted the main things like subs ampetc.)
Old May 4, 2010 | 11:36 AM
crx_91si's Avatar
Default Re: rate my system
Old May 4, 2010 | 12:00 PM
RICKSAUTOMOTIVE's Avatar
what are you using for component speakers? i also see you have no dynomat? also you didnt say what size wiring your using for your amp. sounds to me like a basic rattlebox car. the jl subs are the best thing you got IMO. i just dropped $3600 with crutchfeild for my new system 2 months ago. still havent installed it since i am waiting for sandblasting and paint. maybe i'll post the components later for you to see what some of us like
Old May 4, 2010 | 03:01 PM
well i have the kenwood excelon kdc-x994 head unit with ipod cable kenwood kdc-ip101, kenwood kdc-c719 10 disc cd changer, infinity kappa 32.9cf speakers, infinity kappa 42.9i speakers, infinity kappa 52.9i speakers, kenwood excelon x1200m sub amp, rockford fosgate prime r150-2 dash speaker amp, kenwood excelon x600f door speaker amp, jl audio 10w3v3-2 subs (2 of them), jl audio sgr 10w3v3/w1v2 speaker grilles (2), tsunami litewave series pp1002tm capacitor, street wires zero noise 5 4-channel patch cable, street wires zero noise 5 stereo patch cables (3 sets-various lengths), street wires clip its 1/0 gauge (x5), also got a 4-gauge one, and a dual 4-gauge set, have various grounding terminals (street wires), got a antana noise filter, power line noise filter, and an RCA ground loop noise filter, dynamat 1 inch and 2 inch rollers, dynamat dynatape, dynamat xtreme mega pak (72 square feet) and i still need a few things. gotta cnc speaker rings for the door speakers to keep my door panel material from ripping and make the installation look good. and i have to make my speaker box still. not in a hurry. i also got a few jvc amps on special with the kappa speakers but i sold them for 30 bucks each cause they were freebies i didnt need
Old May 4, 2010 | 03:33 PM
f22a1 ftw's Avatar
updated to answer all ur questions
Old May 4, 2010 | 03:42 PM
f22a1 ftw's Avatar
sounds like you got a pretty sick setup but why did u mention the dynomat rollers? and yes i have dynomat i got like dynomat xterme pack somthing and my buddy installed it for me but thatwas before my system was even installed had it put in for a more quieter cab
Old May 4, 2010 | 03:43 PM
oh i see i just ran through the packing list right now from crutchfeild. i remembered also because a new crutchfeild catalog came today. gotta do my back yard too now when i do my out door kitchen out there. i want a kick *** system out there too so crutchfeild may be called again LOL i had forgot the rollers were just that. seen part numbers and just typed LOL
Old May 4, 2010 | 03:50 PM
f22a1 ftw's Avatar
yea if ur going like a home radio that slams mtx and alpine/kenwood make some kick *** home stereos or u go the other way with a vcomputer power supply acting as a car battery and run more or less a car system
Old May 4, 2010 | 03:55 PM
no i'm thinking the out door speakers. like polk audio but alot of them. i also have bought stuff through pro sound and stage lighting. its a company dealing with studio and movie lighting equipment or club systems. i have 4 peevey 15 inch 2-ways in my garage with crown 2 amplifiers. i also have 3 mackie amps just sitting in the attic. probably use those for the system out there
Old May 5, 2010 | 08:05 AM
f22a1 ftw's Avatar
bumpz
Old May 5, 2010 | 08:21 AM
edzy's Avatar
Meh @ both setups
this is what was in my acura tl
Kenwood DNX9140
Rockford 3Sixty.2
Peerless SLS 8
Tang Bang Bamboo W3
JL Audio HD600/4
MB Quart DSC280
2 12" SSA XCONS In 4 cubes tuned to 30hz
Sundown 3000D
Old May 5, 2010 | 08:27 AM
f22a1 ftw's Avatar
Originally Posted by edzy
Meh @ both setups
Kenwood DNX9140
Rockford 3Sixty.2
Peerless SLS 8
Tang Bang Bamboo W3
JL Audio HD600/4
MB Quart DSC280
Sundown 3000D
"2 12" SSA XCONS In 4 cubes" what does that mean? but sounds like u have a pretty sick nasty system
Old May 5, 2010 | 08:48 AM
it means his 2 12 inch subs are in a box with 4 cubic feet of air space/volume. depending on what the subs require for air space and the volume the magnets and speaker frame of the subs take up this could be very sick indeed. but if you know about all this stuff you can build bad *** boxes that will bump an 8 inch JL better than some peoples 12 inch subs
Old May 5, 2010 | 08:53 AM
f22a1 ftw's Avatar
yea i dont know aloottt about this i just know basic stuff and how to install/hook up most everything but yea i might get a new box custom built but my dual camphor box to somthing else but for now they hit hard enough for me
Old May 5, 2010 | 09:04 AM
yeah i had 2 12 inch hollywood competitions in my F150 crew cab truck. i raised the rear bench seat 4 inches using 4 inch square tubing steel and i built the box to fit under it and i put my 2000 watt hollywood competition amp, kenwood 2 and 4 channel amps power dist block, and capacitor all behind the seat back there. even ran an ac tube from my ac box to the amps and cap to keep them and the capacitor cool. that truck ROCKED!!
Old May 5, 2010 | 09:44 AM
edzy's Avatar
rick, you could've got so much better with 3600
i mean so much better
Old May 5, 2010 | 09:53 AM
yeah i know but i'm not into the full bass systems any longer. blew my rear window out of my mustang 5.0 hatch back on the freeway with the windows and t-tops off bumpin kid rock. and i'm gettin old LOL. i am on the color matching thing for my build now. that same mustang LOL and i wanted the kenwood **** to match. i have always had infinity component speakers so i am not changing. i did consider the jl speakers too but after a long time with infinity i wont change. even though the jl component speakers sounded just as good and would match the subs. i still have a few sets of infinitys in the mustang from the last system. gonna give those to good will for a tax write off if my pops dont want em. with a new build its just time for new stuff. no budget for this build either. going to SEMA next year with it
Old May 5, 2010 | 09:56 AM
edzy's Avatar
i guess it's worth it since u like it.
Old May 5, 2010 | 10:07 AM
yep we're all different. systems are seriously like oil brands. honestly i like the clarion head units too. i have had them and pioneer and kenwood and sony, and pannasonic, and alpine, but i like clarion the best. but for this build i like that the usb wire on the kenwood can be routed to the glove box. i see so many young builders now with their systems but theres a crappy lookin wire out the face of the head unit for the ipod. just looks crappy to me. so the kenwood wire can be routed through the rear of the deck to the glove box for a clean and hidden look. i dont even have an ipod yet cause the last one i paid 250 for it but i didnt know how to down load songs off it and since i like stuff from the 80's no one wanted to spend the time putting my cds on it so i gave it away. thats why i got the cd changer too. maybe this time i'll get someone to down load my cds for me to my new ipod. i'm gonna offer a free ipod like whatever i get to anyone willing to do that for me. and i had an ipod that said it could hold 66,000 songs so i forgot what it was but it was 250 bucks. thats a good trade huh? yep i still buy cd's.
Old May 5, 2010 | 07:08 PM
f22a1 ftw's Avatar
one of my jls broke gonna get 2 audiobahns off a freind for free scince i found him the deal on them and a amp for 50 bucks but yea one of jl audio subs the cone seprated from the idk how to say this but the rubberish round part going around the cone anyone know how to fix it "note im not technical with subwoofer repair" so help would help me but yea can i repair or just get 2 audiobahns are temp replacements(would rather fix the jl)
Old May 6, 2010 | 11:05 AM
i know of a speaker repair shop that does this but i think its lie 75 bucks and the place in near hollywood california. i didnt even know they had such shops but my uncle sent me there to replace that part for his 15 inch technique speakers from the 70's. they still rock now again LOL
Old May 6, 2010 | 12:43 PM
twentyhurtz's Avatar
I like the subs, good amp kit, i think the capacitator is a massive waste of time and money in every single audio system on earth.. for the price of a cap you can get a sla 33 ah battery or smaller. jvc head unit is ok, i have sold jvc before but i'm a die hard alpine fan till the bitter end. props for choosing components of any kind- better than a coax setup. and good job choosing sound deadener, even though dynomat is the most pop name, it is rather expensive.
Old May 6, 2010 | 12:44 PM
oh and good luck with those audiobahns, i went through 6 audiobahn 1805q's before i said the hell with that ****.
Old May 6, 2010 | 12:47 PM
if the surround (rubber part between cone and basket) has separated, you can glue it back- if its on the frame size, if its a puncture hole, use finger nail polish- it works, but if its a foam surround, that is a lot harder to fix. I know partsexpress.com sales replacement surround for subs, last time i looked on there i saw the red surround used on the old CV Vega subs.
Old May 6, 2010 | 12:59 PM
i have an odyssey battery going in the car with my newest system. i have them in my other cars (5 vehicles) and i had them in my boats in the past (6 batteries in 2 boats) the odyssey batteries are the best IMO. expensive but made in the USA with no recycled materials. even the lead is mined in the US. missouri i believe
