radio problem
i went to install a car radio, and cut the factory clip off. do you know anywhere i can buy the factory clip with the exact colors of the wires
is there any other options to install it! Thanks!
Are you installing a stock HU, [radio] or an aftermarket one?
The stock radio harness plug, [clip] can be found at any bone yard, PicknPull if you want the same exact wire colors, or you can get a "reverse" harness, [with universal colors] from any car audio shop and connect it to the stock radio harness.
If your installing an aftermarket HU you would just hard-wire it's harness to the cars stock radio harness, using either butt connectors or solder and shrink tubing.
What is the MM&Y of the car? 94
Thanks for replying.... I have a 2006 Civic EX coupe. The photos of the "double din" unit is a stock head unit from a 2006 Civic Hybrid that I'd like to install into my EX Civic. There are more plugs in the back of the "Double Din" than my factory "Single Din" set up. I plugged all of the radio plugs that would fit from my car into the "Double Din" unit and got nothing.. It is my hope that someone would have already done this swap and if a aftermarket harness could be bought that would allow me to plug my car radio harness in to it and the other ends would plug into the factory "DD" radio...
nbcivic
Audio / Security / Video
May 20, 2010 01:36 PM
GuCCi_GSR
Oct 27, 2008 05:09 PM
R-81DC2
11
Apr 2, 2007 04:10 AM
