Radio keeps restarting
Old Sep 20, 2012 | 05:25 PM
tarudude's Avatar
Default Radio keeps restarting
So I've tried searching for a solution on google and have only found few results, most of which are irrelevant to my situation. For anybody who drives a lowered vehicle, I was wondering if any of you have come across this issue. I've noticed when i drive over an uneven pavement surface or concave manhole my car makes a *thud* noise and the radio restarts. I do have an aftermarket set-up if that will make it any clearer as to what the problem might be.
Old Sep 20, 2012 | 10:11 PM
BrotherAli's Avatar
Default Re: Radio keeps restarting
Probably a loose connection best thing to do is to look at connections and ground.
Old Sep 20, 2012 | 10:15 PM
tarudude's Avatar
Yeah I figured it might be a loose connection causing it. Just wanted to see if anyone had dealt with this from personal experience and have figured out a solution to prevent it.
Old Sep 24, 2012 | 05:54 PM
fcm's Avatar
fcm
Old Fart
The solution is to find the bad connection and fix it, if a bump will cause the problem it is a good bet that just moving/pulling on the radio harness will also cause the problem, making finding the bad connection pretty easy. 94
em2-matt
Honda Civic (2001 - 2005)
Mar 26, 2010 08:29 AM
htsang07
Audio / Security / Video
May 4, 2009 11:59 PM
eskimo10
Jun 19, 2007 05:54 PM
johnny mittens
Honda Fit
Jun 14, 2007 02:57 PM
Professor_Phucktard
29
Feb 3, 2005 04:26 AM
