Problems with Clifford Concept 100
I just installed the alarm into my 98 integra and I have been having a wierd problem with it. When I arm the alarm it locks all the doors and funcitons correctly and when I disarm it it unlocks correctly aswell. The problem is when I arm the alarm again within a couple seconds it locks the doors and sets the alarm off. After checking which code it throws on the LED it blinks four times meaning the door triggers set it off. I've checked all my door triggers and they are all functioning (pushed in).
I don't quite understand why it would do this. To set the alarm again once this occurs I usually have to wait a couple minutes before I can rearm it. Can it be my wiring that is causing the malfunction? I used the wiring diagram from DEI to wire the alarm up so I would assume that it was correct.
I never actually noticed this but do 98 up integras have a courtesy light thing. If so I believe this may be why my alarm might be going off.
hatchinprogress
Audio / Security / Video
10
Jan 14, 2005 05:21 PM
