problem with door trigger wire on my civic 4dr
Old Nov 9, 2008 | 11:44 AM
itsJDMyo's Avatar
Default problem with door trigger wire on my civic 4dr
I have a 96' civic 4DR and have installed a viper 5900 alarm in it. everything works fine besides the fact that only the 2 front doors trigger the alarm when it is opened. but when i open the 2 rear doors, it doesn't trigger the alarm to go off. i have wired the door trigger wire to the "light green/red" wire in the driver side kick panel. but after doing some research, in order to make the 2 rear doors trigger also, is to wire up the same colored wire, but the thicker wire. but i can't find that wire anywhere. any inputs on how to wire my 2 rear doors??? thx in advance!
Old Nov 9, 2008 | 12:21 PM
KRock459's Avatar
Default Re: problem with door trigger wire on my civic 4dr (itsJDMyo)
It is in a grey plug fastened down low behind the drivers kick panel. It looks to be a thicker gauge wire (14 gauge) and is green/red stripe. It can be tricky to get to, you can also find the dome light wire in the drivers side "A" pillar, it catches all 4 doors.
Kirk R
Old Nov 9, 2008 | 03:00 PM
fcm's Avatar
fcm
Old Fart
You can find the lead at the OEM alarm plug, green plug to the right of steering column, you will also find the trunk/hatch trigger there . 94
Old Nov 9, 2008 | 03:21 PM
itsJDMyo's Avatar
Default Re: problem with door trigger wire on my civic 4dr (fcm)
what if i the car didn't come with an oem alarm? i bought the car used, so i'm not sure. will the green plug be there regardless? or only for oem equipped alarms? and do you know the color wire for the trunk trigger? i've been looking but can only find the hood trigger wire
Old Nov 9, 2008 | 07:02 PM
KRock459's Avatar
They are all pre-wired for the OEM alarm, the plug should be there. It will have doors, trunk, lights, and horn honk
Kirk R
kjrayo18
Jul 21, 2014 06:47 AM
SHG_Mike
Jun 24, 2007 11:52 AM
ScottEK
Audio / Security / Video
Jul 23, 2003 10:06 AM
willyboyK20
Apr 18, 2002 04:51 AM
