prelude power door lock question
Old Jul 3, 2005 | 02:49 PM
Sabbotage's Avatar
Default prelude power door lock question
I got a 92 prelude with power locks that im installing a keyless entry system into because my drivers door wont lock/unlock with the key. I was wondering if preludes that year had a 2 stage lock system where i could press the unlock button once and get just the drivers door and the second time unlock the passenger door? If i unlock the passenger door with the key, it unlocks both doors but since the drivers door doesnt work with the key Im not sure if it just does the drivers door or both at the same time like the passenger door does. Can someone enlighten me?
Old Jul 3, 2005 | 05:16 PM
fcm's Avatar
fcm
Old Fart
Default Re: prelude power door lock question (Sabbotage)
It probably does both doors, does the key less entry have priority door unlock as an option?, if it does with a pr. of relays you could do priority door unlock, otherwise just wire the lock wire to the cars black/white wire and the unlock to the cars black/red wire in the 10 pin connector in the pass. kick panel. They are neg. (-) trip.
Old Jul 3, 2005 | 09:19 PM
Sabbotage's Avatar
Default Re: prelude power door lock question (fcm)
hmmm ill have to look and see if thats in the manual. If so i guess ill get a few relays and wire it up.
Old Jul 4, 2005 | 07:47 PM
rjr162's Avatar
as long as your keyless has two differnet outputs, you could always make it have priority... using a little thinking, a few relays (or a 451M).. and a bit of extra wiring
Old Jul 5, 2005 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: prelude power door lock question (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">as long as your keyless has two differnet outputs, you could always make it have priority... using a little thinking, a few relays (or a 451M).. and a bit of extra wiring </TD></TR></TABLE> You mean two diff. unlock outputs, don't you, a priority and an all door? they all come with two, lock and unlock 94
Old Jul 5, 2005 | 08:21 AM
rjr162's Avatar
ok ok, two "outputs" other than lock. You *can* use the unlock output and a 2nd unlock output if it has it, or you can use an AUX output also.
karrar55
Honda Civic (2001 - 2005)
Feb 18, 2014 01:06 AM
kornerk12
May 25, 2009 03:52 PM
carcraftlude
Audio / Security / Video
10
Oct 3, 2008 07:56 AM
M2B4
May 10, 2008 04:46 PM
