POWER Wire For Headunit. What Colour??
Old Dec 18, 2004 | 11:00 AM
1 Cam Wonder's Avatar
Default POWER Wire For Headunit. What Colour??
Im wiring up my headunit, just a shitty Blaupunkt.
Ive got all my hardwires for my 4 new speakers all run and connected but I need some help on the power wire
What wire am I tapping for the power for the headunit? Hopesomeone knows the color off hand. Wanna finish this shortly
Thanks
EDIT- The RED/YELLOW from my cars harness has power with the ignition on
From my cd player I have a RED wire labelled IGNITION and a YELLOW wire labelled BATTERY 12+V
Also the WHITE/BLUE wire from my cars harness never seems to have more than 1.16 of power.
Ive had this cd player in my car, but it was stolen and recoverred.
Ive tried different combo's of hooking up the power wire to the red and the yellow from the cd player and the dam thing wont turn on. Ground is also connected no prob
Modified by 1 Cam Wonder at 1:41 PM 12/18/2004
Old Dec 18, 2004 | 01:04 PM
GSteg's Avatar
the yellow should be the one that is constant to your headunit. the red ignition wire is basically a trigger for the headunit to turn on.
Old Dec 18, 2004 | 01:08 PM
Default Re: (GSteg)
Ya I just wired it like that
Blue/White -> Yellow
Red/Yellow -> Red
But like I said, the blue/white is supposed to be constant power right? Maybe I blew the fuse?
With the car turned on the red/yellow is throwing like 14volts, but I still cant get the cd player to turn on, would the blue/white blown fuse cause that?
I gotta buy some fuses then. I couldnt find the "backup" fuse in my fuse box under the hood. Where is it?
THanks
Old Dec 19, 2004 | 08:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: (1 Cam Wonder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">Ya I just wired it like that
Blue/White -&gt; Yellow
Red/Yellow -&gt; Red
THanks</TD></TR></TABLE> The blue/white wires fuse is the 7.5 amp. fuse in the engine bays fuse box. 94
Old Dec 19, 2004 | 01:24 PM
Default Re: (fcm)
this is for a Crx not an EG, theres no 7.5 under the hood
Old Dec 20, 2004 | 07:04 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">this is for a Crx not an EG, theres no 7.5 under the hood</TD></TR></TABLE>OK..... it may not be a 7.5amp , but the backup fuse should be in the underhood fuse box like it is on every other Honda/Acura I have seen, evan my 94 teg has a 7.5amp backup fuse, if your CRX has a problem on that line, why not just run the HUs yellow to the fuse box, or better yet, to the batt. 94
Old Dec 20, 2004 | 09:31 AM
Default Re: (fcm)
well if I run it to the battery, Ill still be able to turn it on and off so it isnt constantly draining power right?
I was thinking of doing that
Old Dec 20, 2004 | 11:02 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">well if I run it to the battery, Ill still be able to turn it on and off so it isnt constantly draining power right?
I was thinking of doing that</TD></TR></TABLE> Yes 94
Civic041504
Audio / Security / Video
May 21, 2011 11:19 PM
smartguysjt
Dec 17, 2010 08:06 AM
1 Cam Wonder
Dec 18, 2004 04:12 PM
tianporn
Jun 25, 2004 05:50 AM
TegDroP
Jul 3, 2003 07:17 AM
