power door locks in ef hatch
Old Dec 16, 2006 | 05:27 PM
408wdy's Avatar
Default power door locks in ef hatch
i got my viper 791xv to work all excpet the power door locks. i can't figure out what wires control them.. i thought it was the blue/black green/black but i was wrong? or maybe im missing a ground.. some input would be appreciated, thank you
Old Dec 16, 2006 | 05:52 PM
fcm's Avatar
fcm
Old Fart
Default Re: power door locks in ef hatch (408wdy)
http://www.directwholesale.net...eID=3 94
Old Dec 16, 2006 | 08:54 PM
suspendedHatch's Avatar
Default Re: power door locks in ef hatch (fcm)
Actually I think he's asking for this:
Old Dec 17, 2006 | 02:21 AM
408wdy's Avatar
Default Re: power door locks in ef hatch (suspendedHatch)
^^ thats exaclty what i was lookin for thank you
Old Dec 17, 2006 | 07:22 AM
fcm's Avatar
fcm
Old Fart
Thats what I thought, but what Viper 791xv has door lock relays built in?????
http://www.directeddealers.com...5.pdf 94
Old Dec 17, 2006 | 08:45 AM
Hm. I guess he's using the 451m. Maybe someone should tell him just to use the blue and green wires directly.
Old Dec 17, 2006 | 09:32 AM
408wdy's Avatar
i hooked up the blue/black and green/black directly to the door regulators but nothin worked.. imma go look @ the wiring again, yesterday it started raining out of nowhere when i was finishing the install so i had to stop.
Old Dec 17, 2006 | 03:56 PM
audioroach's Avatar
You need 2 relays ( bosch or DEI 451m relay pack) to make it work.
Old Dec 17, 2006 | 05:22 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Hm. I guess he's using the 451m. Maybe someone should tell him just to use the blue and green wires directly.</TD></TR></TABLE>Maybe he has aftermarket actuators .
408wdy Are the power door locks stock, or are you trying to add power door locks?
Also is it the Viper 791xv alarm/remote start?
Are you using the DEI 451M, [door lock relay module]?
If they are stock power door locks you do not need the 451M, do as suspendedHatch suggests and use just the green and blue wires on the 3 pin door lock port on the main unit.
If they are aftermarket actuators you will need the 451M, but wired a little differently, sorry can't find a DEI wiring diagram but the green/black and the blue/black, [#30] still go to the actuators, the white/black and brown/black, [#87a] go to chassis ground and the violet/black and violet. [#87 with the fuse] goes to a 12V+ constant source, [constant power free pin on under dash fuse box] 94
Old Dec 17, 2006 | 05:39 PM
408wdy's Avatar
you cleared that up for me very well thank you..the actuators are aftermarket 2 wire. where can i get these relays at? radio shack or frys electronics?
Old Dec 17, 2006 | 06:06 PM
fcm's Avatar
fcm
Old Fart
Do you not have the 451M door lock relay pack, I got the impression when you said... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 408wdy &raquo;</TD></TR><TR><TD CLASS="quote">^^ thats exaclty what i was lookin for thank you</TD></TR></TABLE> if that's not the case, then get the relays, SPDT 12V relays, it is a standard relay used in car audio/security, they can be had at any car parts store, car audio/security shops or more then a few online shops... http://www.google.com/search?s...elays and you will wire them like this "Actuators/Reverse Polarity"... http://www.the12volt.com/doorlocks/page3.asp#arp you can not connect the Viper 791xv " low current" door lock outputs, [green and blue] directly to the actuators, hopefully if you did that, the outputs are not blown. 94
Old Dec 18, 2006 | 07:28 PM
tha_badguy's Avatar
does the compustar 2w900fm have built in door lock relays...?
Old Dec 18, 2006 | 10:53 PM
408wdy's Avatar
Default Re: (tha_badguy)
yeah im using the 451 relay i got it hooked up now and it works fine.. thank you!!
Old Dec 19, 2006 | 01:49 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">does the compustar 2w900fm have built in door lock relays...?</TD></TR></TABLE> No it does not. 94
Modified by fcm at 7:09 PM 12/19/2006
skidmarkroyalty
13
Mar 24, 2009 02:00 PM
franckcrx
Nov 19, 2008 12:19 AM
408wdy
Dec 15, 2006 09:49 PM
ca_delsol
Audio / Security / Video
Jul 2, 2005 10:45 AM
eddie1681
16
Sep 24, 2004 11:14 PM
