O.E. Wiring Harness Question
Old Mar 8, 2007 | 07:54 PM
texas_tea_2k6's Avatar
Default O.E. Wiring Harness Question
I ordered a wiring harness like this one
http://www.scosche.com/scosche...A02RB
I was wondeing it itll be easy to connect, will it be color coded? Will it be as easy as connecting one of these harnesses?
http://cgi.ebay.com/Radio-Inst...wItem
Also what is meant by the term hard-wiring?? I have a good idea but just want to be sure
Any advice please. Thanks
Old Mar 8, 2007 | 08:49 PM
suspendedHatch's Avatar
Default Re: O.E. Wiring Harness Question (texas_tea_2k6)
They're the same thing. Yes, they're color coded to the universal aftermarket stereo colors. You'll have to hardwire that to the harness that comes with your new stereo. If you're not comfortable crimping or soldering, you could go to Circuit City and buy the plug in harnesses instead. Problem is that they only carry them for the brands of stereos they sell.
What stereo is in your car now? Hopefully no one has cut off your stock harness.
Old Mar 8, 2007 | 09:00 PM
Default Re: O.E. Wiring Harness Question (suspendedHatch)
I own an alpine and yes the stock harness is cut. Thats what I ordered today and i was wondering if itll be hard to install that back on
Old Mar 8, 2007 | 09:54 PM
imadigitalgod's Avatar
if you can solder, then it shouldnt be hard at all. personally i hate crimping wires because over time the connection can work loose, with soldering u know its a 100% good connection for a long long time if done right.
Old Mar 9, 2007 | 03:52 AM
Default Re: O.E. Wiring Harness Question (imadigitalgod)
Im looking through a Haynes repair manual, does anyone know what exact page i can find the wiring diagram for the stock radio wiring? (i connector was cut off but im needing the diagram to add another connector.
Old Mar 9, 2007 | 10:31 AM
im sure its in the electrical section. it will be in the form of a schematic, pretty sure of that. it iwll tell u what wire colors they are tho
Old Mar 9, 2007 | 05:38 PM
fcm's Avatar
fcm
Old Fart
Will this help... http://www.installdr.com/Harnesses/HA-Wiring.pdf ? 94
Old Mar 9, 2007 | 07:07 PM
Default Re: O.E. Wiring Harness Question (fcm)
i will find out tomorrow. It should do tho
Old Mar 9, 2007 | 07:08 PM
ill look through it again and see
Old Mar 13, 2007 | 11:58 AM
ok i got the cd player wired and it plays. When i turn the car ignition on my settings are gone. Im thinking my issue is as follows:
One of my connection consist of 12 volt batter, 12 volt memory and, and a red w/yellow strip that comes from the oem setup?
I want to know its it should the connection even have 3 wires or should it be just 2 wires coming from it?
Old Mar 13, 2007 | 05:58 PM
fcm's Avatar
fcm
Old Fart
OK, give me a sec. to decode what you posted...
"ok i got the cd player wired and it plays. When i turn the car ignition on my settings are gone. Im thinking my issue is as follows:" When you turn off the ign. you loose your radio presets and time, [if the HU has a clock].
One of 3 things is wrong, you have miswired the HUs red, [acc. or switched lead] and yellow, [constant power] you have them crossed, You have a blown fuse, [no power] on the HUs yellow constant power, your HU has a problem.
"One of my connection consist of 12 volt batter, 12 volt memory and, and a red w/yellow strip that comes from the oem setup?" Sorry can't decode that.
" I want to know its it should the connection even have 3 wires or should it be just 2 wires coming from it?" Sorry.
The stock radio harness like I gave you has all the color codes there are 3 power wires in the stock harness 12V+ acc., it is the 'switched" power, 12V+ constant, it's hot at all times, used for HU memory, and 12V+ illumination, hot when park lights are on.
Your aftermarket HU will need the 12V+ acc. and the 12V+ constant, it may or may not need the 12V+ illumination. 94
Old Mar 14, 2007 | 06:34 AM
Ok to make this a little simpler, look @ this wiring diagram http://www.installdr.com/Harnesses/HA-Wiring.pdf
From what you see on it, what wires should these be crimped to?:
Yellow/+12 Volt Battery/Memory ---->
Red/ +12 Volt Ignition/Acc.-------->
Not shure if its correct but right now i got both of these crimped together with 1 other wire which is the oem battery connection, i forget the wire color. Let me know if that made anymore scents :D
Old Mar 20, 2007 | 09:44 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">They're the same thing. </TD></TR></TABLE>
no they're not....
one's a factory style plug...like a 1721... and the other's aftermarket...1720
Old Mar 20, 2007 | 10:43 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texas_tea_2k6 &raquo;</TD></TR><TR><TD CLASS="quote">Ok to make this a little simpler, look @ this wiring diagram http://www.installdr.com/Harnesses/HA-Wiring.pdf
Yellow/+12 Volt Battery/Memory ----&gt;
Red/ +12 Volt Ignition/Acc.--------&gt;
</TD></TR></TABLE> Yellow to white/yellow, +12V battery power and red to yellow/red +12V ignition wire.
Mtntech
Honda Civic (2001 - 2005)
Feb 26, 2014 07:48 AM
TSME
Audio / Security / Video
May 24, 2013 03:51 PM
Bradstard
Mar 1, 2007 02:18 PM
rioninja
Oct 15, 2005 01:23 PM
cademan
Jul 10, 2004 11:43 AM
