No Power to Amp
Old Aug 23, 2002 | 12:30 PM
Understeer's Avatar
Default No Power to Amp
Amp to Subs. Checked all connections and they seem to be fine. Deck works, all components work, but amp doesn't get any power.
What are some things to check for?
Old Aug 23, 2002 | 12:45 PM
GSRaCeRbOI's Avatar
Default Re: No Power to Amp (Fj)
remote wire
that you remembered to put fuse in the power wire from battery (hey it sounds basic.. but I've seen ppl forget to put the fuse in and be like why doesnt my system work)
ground wire
everything is connected correctly (remote, power, ground, RCAs, speaker wires, amp to sub setup)..
even though they seem fine.. recheck ALL the connections..
Old Aug 23, 2002 | 12:51 PM
Understeer's Avatar
Default Re: No Power to Amp (GSRaCeRbOI)
I was re-wiring the power wire to the amp, and I think I saw a spark. I left the fuse in. Could something happen to my fuse or wire? IF so what do I do?
Old Aug 23, 2002 | 12:53 PM
GSRaCeRbOI's Avatar
if all your wiring is correct.. check to see if the fuses are blown.. if so replace them theres fuses inline w/ the power wire and fuses on the amp.. the head unit should also have a fuse.. but if the head unit turns on it should be OK... check the amps and power wire fuses w/ everything OFF>.
Old Aug 23, 2002 | 01:06 PM
Understeer's Avatar
How do I know if the fuses are blown?
Old Aug 23, 2002 | 01:18 PM
GSRaCeRbOI's Avatar
they will look blown/the metal part inside will look melted..
sorry these are bad illustrations.. :
normally its something like this ====== (all connected)
if blown its broken like this === === (blown/melted..the metal fuse/contact doesn't connect)
yeah I know the illustrations suck.. but you get the idea...
[Modified by GSRaCeRbOI, 2:21 PM 8/23/2002]
Old Aug 23, 2002 | 01:53 PM
o_Rage_o's Avatar
if you saw a spark, you blew a fuse. Check back of amp, check radio fuse for car.
-Rage
Old Aug 23, 2002 | 03:04 PM
Understeer's Avatar
Default Re: No Power to Amp (o_Rage_o)
It was the fuse, burnt to a crisp.
Everything is good now.
Thanks for all the help.
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
SIC_jdm_da9
Apr 23, 2007 10:33 AM
Skitals
18
Sep 16, 2003 08:27 PM
Ronin Integra8
Jun 3, 2003 05:18 PM
jamal-188
Jul 8, 2002 06:21 PM
