new head unit install ?'s...
Old May 11, 2012 | 10:26 AM
hyperblu's Avatar
Default new head unit install ?'s...
I have a 99 civic and I should be getting my headunit any minute from ups. I'm just wondering if I absolutely have to use the dash kit, or can i just replace my stock cd player (since it's single din anyway) and keep the original OEM pocket at the bottom? I bought the kit just in case, but was hoping I dont have to use it.
Old May 11, 2012 | 11:36 AM
mikekh10a's Avatar
Default Re: new head unit install ?'s...
it won't be as secure if you don't use it. so if a thief breaks in, the headunit would most likely slide right out, while the dash kit will keep it a bit more secure.
Old May 11, 2012 | 07:13 PM
ef_newb's Avatar
you can bolt it to the bracket the same way that the stock radio was.. personally i think it looks a bit off tho
Old May 12, 2012 | 11:13 AM
fcm's Avatar
fcm
Old Fart
You do not need a kit, you will have to do a little modding, the ISO mounting holes in the stock housing, step #15... http://www.installdr.com/InstallDocs...PDF/466005.asp will need to be filed so the HU sits in the correct location.
ISO mounting is a lot more secure then when using a kit. 94
Old May 12, 2012 | 04:01 PM
hyperblu's Avatar
I got it in. I used the kit... looks quality. :D
peteyb
Audio / Security / Video
12
Mar 13, 2012 11:30 AM
MattBernazzoli
Apr 17, 2009 04:04 PM
supracrx
Jan 21, 2009 07:10 PM
CivicPride97
Acura TSX
May 19, 2008 06:09 PM
allm0torGSR
Aug 13, 2007 05:41 PM
