need to know the exact mounting depth
Old Jun 5, 2003 | 10:06 AM
xXxS_SxXx's Avatar
Default need to know the exact mounting depth
i have a civic coupe and i need to know how deep is the maximum mounting depth in the doors?
this will ethier make or brake my project any help would be great
Old Jun 5, 2003 | 10:36 AM
xXxS_SxXx's Avatar
Default Re: need to know the exact mounting depth (xXxS_SxXx)
nvm got the answer
Old Jun 5, 2003 | 06:07 PM
t0p_sh0tta's Avatar
I'm nosey. What'cha doing?
Old Jun 5, 2003 | 07:59 PM
xXxS_SxXx's Avatar
Default Re: need to know the exact mounting depth (t0p_sh0tta)
im thinking about installing jl audio 6w0 sub-drivers in my doors for mid-bass drivers (the mounting depth is 3.5").....the reason being im running a alpine mrv-f450 which is a 5 channel amp and the fifth channel is 4 ohm stable only so i was going to run a set of 8 ohm speakers in parrel so it will drop the impedance to 4 ohm and i wont have a problem between the speaker and the amp
Old Jun 6, 2003 | 05:35 AM
t0p_sh0tta's Avatar
I'm pretty sure that you can squeeze them in there with a 1" spacer, but you'll have to worry about them hitting the door panel. Good luck.
Old Jun 6, 2003 | 06:00 AM
nOOber's Avatar
curious too,
1 per side, or two per side?
if one per side, then they'll be mono ?
Old Jun 6, 2003 | 06:21 AM
xXxS_SxXx's Avatar
Default Re: need to know the exact mounting depth (nOOber)
one per side but they will be in stereo by the way my componets hook up
Old Jun 6, 2003 | 08:23 AM
rcurley55's Avatar
New User
Not to **** in your weaties, but the cones on the 6W0's are too heavy to be good midbasses...they have been designed as true subwoofers. You also really don't want midbasses to play in mono...it will smear your stage everywhere.
Old Jun 6, 2003 | 08:44 AM
xXxS_SxXx's Avatar
Default Re: need to know the exact mounting depth (rcurley55)
ok i see what your sayin any ideas (other then a new amp)
ok bear with me here so i could run these speakers as subs in the doors right?
then it wouldnt matter if its stereo or mono?
my overall goal here is to level out the bass in the car so it not all coming from the rear!!!
i plan on running about 90-100hz to these is that still a problem
Modified by xXxS_SxXx at 12:06 PM 6/6/2003
Old Jun 6, 2003 | 09:19 AM
nOOber's Avatar
90-100 as your high pass or low pass ?
Run them as low they can go, and maybe up to 100-120 (?) for the high pass cut off. If you go higher, the low end of your sound stage will be in mono.
Also, how steep is your x-over?
I'm wondering if you'll see a peak when the sub and the mid bass meet...
Old Jun 6, 2003 | 10:48 AM
xXxS_SxXx's Avatar
ok heres the setup
on my subs im running about 45hz +/-12db
on the 6w0 in the door i can run them lowpass 80-250hz.... no problem but ill be looking for 80-100hz +/-12db mostly...
the subs signal is cut off at about 60 or 65 hz i think so there is a slight chance that the subs and these will ever peak together
well there is another thing im also running a set of jl audio 2 way components for my highs and mids
the 6w0 are just for signals around 80-100hz
Old Jun 7, 2003 | 03:35 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
I'm a car audio tech.... if ur civic is '96-up... forget it. Unless you build custom kickpanels... its much easier that way. We build custom fiberglass kickpanels for $250. Most reputable shops will probably be around $200-$400. Sometimes u can even stuff 8" in them too. That sounds bad azz with a bandpass x-over.
Old Jun 7, 2003 | 03:57 PM
ScareyH22A's Avatar
Community Builder
Also... I do a lot of tuning for competitions, here's a quick soundstage tip. To make ur bass sound like its coming from the front, get a high band (the more bands the better but more of a headache), quality eq like from Audio Control. X-over the fronts with bass frequencies maxed out on the eq. Now, with the x-over set, set all the frequencies to middle, and slowly lower the midrange x-over frequency (like around 80Hz) until u get clean bass out of ur mids. Then slowly raise the subwoofer frequencies (usually around 80Hz) until ur soundstage is perfect. The end result it a midrange starting to hit the bass while ur subwoofer finishes it off. It tricks ur brain into thinking that the bass is coming from ur doors. X-overing the frequencies to match at 80Hz won't do it. You've gotta fine tune the x-overs at around that frequency and than raise or lower the actual level of the mid and sub. If done right, you'll be amazed.
Old Jun 9, 2003 | 12:11 PM
xXxS_SxXx's Avatar
Default Re: (ScareyH22A)
i have audio control eqs and a 6xs but i dropped the sub in the door idea and im just running a set of jl audio components in a set of kicks but thanks for the help
EG-SIXV-TEC
Audio / Security / Video
Aug 19, 2012 12:59 PM
screen_name
19
Nov 27, 2006 05:09 PM
92BluEH-3
Jun 25, 2005 03:10 PM
BoOsTiN Dc2
Apr 20, 2005 05:20 PM
kkim
Apr 24, 2002 02:04 PM
