Need Help choosing Amp Size
Ok.
I just want to upgrade my stock sounds, I am getting 2 6x9 (300w each) and 2 6 1/2 (200w each) and a small sub (200w).
What kind of Amp do I need. I preffer to have just 1 Amp for all.
Not really sure what to get. And I don't understand much of this 1-4 channel thing. And do I need a capacitor?
Thanks for the help.
ok, first of all, you need better information, just saying your 6x9's are 300w each helps me none, because i'm 99% sure 300w is a MAX rating, what you need to do first of all is look up each speaker/ subwoofer and get the Continuous (RMS) power rating for each. Then the sub, i need to know its RMS power rating too, as well as what voice coil configuration it is. Yes you can get a single amp to accommodate all the speakers in your setup, but choosing one will depend on the questions i have asked you above. More than likely from the sounds of your setup, its gonna be a small 5 ch amp and will not require a capacitator.
he ya go
might actully need a better sub for this amp
its 75 rms to all 4 speakers and 300 to sub
http://www.crutchfield.com/p_500PDX5...3&tp=115&avf=N
and no you dont need a cap
ok well you still didn't tell me what ohm load the sub was, that matters alot! anyways find a 5ch amp, the mids/highs section needs to be atleast 50-75w rms x4@4ohm stereo and the sub section 100-200w rms@4ohms - i say this because man 5ch amps have a sub section of about 200w-350w rms on average, and some even 1100w rms for the sub section ( memphis belle) but yea, i wouldn't get a bazooka bass tube, they are so OLD and sound like junk to me... i would get like a 10w0 or something if your just wanting something small, but if your dead set on a bass cannon, we need to know the rms, i'm not a fan of bazooka but from memory it THINK they came in svc 4ohm and dvc 4ohm or svc 2ohm..
Is there a specific numbers I have to look for in speakers to have a good bass.
I might have to cancel the bazooka. I just want to have good enough bass but not overwhelming.
Also is it ok to use an AMP that has 75-50 RMS rating for a speaker that has a 100 RMS rating, what are the CONS?
Thanks
Thanks
they need to see at least 75 watts rms 100 watt would be ideal
if you look at the link i posted that amp will give them 75 each and still have 300 for a sub that should provide a good bump.
Make and model numbers of the speakers and the sub would have been better, but continuous, [RMS] power handling will work.
I agree with 98civdx the Alpine PDX-5 will do the job, and no you do not need to worry about speaker, [sub] impedance as Alpine PDX amps RMS output is the same at 2 or 4 ohms.
With that said I would recommend that you get two amps a 4ch and a mono block sub amp...
This is the 4ch I would recommend... http://www.crutchfield.com/p_1363004...v2.html?tp=115 and then find a 100W-150W mono block sub amp, something like this... http://www.crutchfield.com/p_136G130...00.html?tp=115
There is nothing wrong with the Bazooka tube as long as it is installed properly.
If you are on a budget and Alpine and JL Audio is out of your price range then look at MTX amps, very good bang for the $... http://www.mtx.com/index2.cfm 94
interesting - didn't know that about pdx amps, regulated sub section? but i quit working at an alpine dealer in 05 and i don't think those had yet come out, i've been out of the loop lately..
i agree with fcm. you will see best results with 2 amps but if you only want one the pdx5 will work great.
both amps he posted are great. i have installed them and played with them. and have noithing but positive things to say mtx included.
twentyhurtz- i think they just came out. but the are the smallest amp i have ever seen and make the kind of power they do. just pretty expensive compared to other amps with same output. and as with everything alpine makes quality is fantastic.
ls-t del sol
Audio / Security / Video
Dec 16, 2003 02:00 PM
Jazezy
Oct 19, 2002 10:21 PM
