Need help with audio... subs are not working
Old Aug 17, 2008 | 08:02 AM
Rizzen's Avatar
Default Need help with audio... subs are not working
Problem: Subs are not working
I was moving my amp, and the [not good with elect. stuff so im gonna guess a name for it ] DC cord fell out [ wire that powers the amp and subs ]. So, I stuck it back in for a moment... It came back on... Fell out again, and I stuck it back in there again... but this time there was no sound. Little Green Light on amp is on, indicating power to the amp. So, is there a fuse thats runs the subs or ... what?
Appreciate the help.
Can also call me at 228 257 9009
Modified by Rizzen at 2:08 PM 8/17/2008
Old Aug 17, 2008 | 08:27 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Need help with audio... subs are not working (Rizzen)
power wire? sub wire? Can you post pics of what you did?
Old Aug 17, 2008 | 10:22 AM
fcm's Avatar
fcm
Old Fart
Check the power cables main fuse, [by the batt.]. 94
Old Aug 17, 2008 | 11:09 AM
Rizzen's Avatar
Default Re: Need help with audio... subs are not working (fcm)
The fuse is not blown, but I heard that sometimes these fuses are little tricky or w/e
Old Aug 17, 2008 | 11:13 AM
okay, thanks for the pics, and dam I luvvvvvv some vtakkkkkkk. The fuse looks good even thou I don't reccommend using atc fuses for amps, Agu are better then those and I hate them, lol. have you check the sub with a small 9 volt battery to see if it moves or pops? Just tap it and see if it moves. Also did the rca come loose on the amp?
Old Aug 17, 2008 | 11:17 AM
Rizzen's Avatar
Default Re: (wrx-killer-Sti-eater)
about to go find 9v battery. rca cords are in tackt.
but did u understand what i meant by "power cable coming loose?" i fell out once, i stuck it back in - subs were fine, fell out second time, and I stuck it back in, subs were not working. could i have fried it or something?
Old Aug 17, 2008 | 11:21 AM
Rizzen's Avatar
Default Re: (Rizzen)
Yup, subs are fine, battery made it pop
Old Aug 17, 2008 | 12:05 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rizzen &raquo;</TD></TR><TR><TD CLASS="quote">
The fuse is not blown, but I heard that sometimes these fuses are little tricky or w/e</TD></TR></TABLE> Is that the fuse in the power cable, and what size and type is it, it's hard to tell from the pix, is it a "maxi" fuse? 94
Old Aug 17, 2008 | 12:09 PM
We are going to need a dvm, can you unplug the rca and see if the green light on the amps goes out. I want to rule out a bad ground. A amp will pull ground thru the rca's. And we need to test voltage at the amp.
Between fcm and me we should have this fixed quick.
Old Aug 17, 2008 | 04:42 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">We are going to need a dvm, can you unplug the rca and see if the green light on the amps goes out. I want to rule out a bad ground. A amp will pull ground thru the rca's. And we need to test voltage at the amp.
Ditto that ^^^
Makes sense that if the power connection is bad so may be the ground, which probably means burnt signal return traces in the HU.
Set screw type connections suck, I hate them.
Hint, when using set screw connections, "tin", [sock in solder] the end of the lead/cable going into the set screw connector, this will make a much better connection, and use the correct gauge of wire/cable. 94
Old Aug 18, 2008 | 03:51 PM
Rizzen's Avatar
Default Re: (fcm)
I couldnt post cuz of this trial crap. But, my RCA's went bad...
I need to rewire my sound system [from the cd player to the amp and stuff]
Can u list the stuff that would be good to use.
Also, I need to rewire my whole car [like headlights and etc] is there a harnest i could buy or ... should i make my car look like an airplane with second battery and bunch of kill swiches
Old Aug 18, 2008 | 04:21 PM
fcm's Avatar
fcm
Old Fart
What do you mean your "RCAs went bad", and why do you need to rewire your car? 94
Old Aug 20, 2008 | 09:54 AM
Rizzen's Avatar
Default Re: (fcm)
Well, I can assume that they went bad, because once I replaced them - subs started working.
Rewire whole car because, someone stole my car for 2 weeks they messed up bunch of crap. Now my fuses keep blowing, headlights arent working, ended up hotwiring that crap. And random wires tend to burn lol...
Old Aug 20, 2008 | 05:12 PM
fcm's Avatar
fcm
Old Fart
Replace the damaged wire harnesses. 94
Old Aug 23, 2008 | 12:30 PM
Rizzen's Avatar
Default Re: (fcm)
Done... now it's fine... how do i get rid of this Trial User crap
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
GsDAteg
13
Mar 14, 2010 07:54 AM
oes
Jun 29, 2005 06:25 PM
jadugartir
Apr 14, 2005 09:26 AM
jamal-188
Jul 8, 2002 06:21 PM
