little help with car audio
Old Jun 23, 2004 | 02:54 PM
Dwight Schrute's Avatar
Default little help with car audio
so i just bought a car and it came with a jvc KD-G300 head unit that is almost brand new. i'm not a big audio fanatic , but i have a pretty good set of cans i use for my computer (sennheiser hd280pro) , so i know what good sound is. i had some bestbuy gift cards so i went and picked up the most shallow speakers that i could find that also sounded pretty good. i needed shallow so i could get them to fit in the door without hitting the window. the speakers i got were the pioneer TS-A1670R's. I was going to get the kenwood KFC-1679ie's but the display models werent working and the pioneers are a bit shallower.
my head unit is 19rms and the speakers are 35rms , so i cant really turn them up loud without them sounding crappy. im not an audio buff , so i dont know what i need to make them sound better. im assuming some sort of amplifer. any help would be appreciated.
Old Jun 23, 2004 | 05:35 PM
PetroGuyX's Avatar
no amplifier is really necessary for those little speakers
Old Jun 23, 2004 | 06:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: little help with car audio (drewthomas14)
19 watts should drive those speakers pretty good if they are installed and wired properly. that said ,you are better off over powered then under powered
A 2x25 or 35 watt amp would be all you need,
hope this helps. 94
Old Jun 23, 2004 | 06:46 PM
Default Re: little help with car audio (fcm)
how would they be wires incorrectly? there is only a negative and positve wire to solder , and then butt connectors to the speakers. it sounds pretty good , but i get distortion if i go past 20 on my volume , and it doesnt sound as clear as they did in the store.
Modified by drewthomas14 at 11:04 PM 6/23/2004
Old Jun 23, 2004 | 08:23 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">how would they be wires incorrectly? there is only a negative and positve wire to solder , and then butt connectors to the speakers. it sounds pretty good , but i get distortion if i go past 20 on my volume , and it doesnt sound as clear as they did in the store.
Modified by drewthomas14 at 11:04 PM 6/23/2004</TD></TR></TABLE>
Well mixing up the pos. and neg. is how you would miswire the speakers[ out of phase]
Sounds to me that you don't think thats the problem,so how about the speaker mounting , are they mounted to a flat surface, do you have a airtight seal between the front and back of the speaker,if so, I would say you need the amp.94
Old Jun 23, 2004 | 08:57 PM
i dont think i miswired them because the one wire had a black stripe on it and i made sure it was the - in the manual. when i tested them i didnt have them mounted correctly because i need to fab some brackets, but i still think they are underpowered as the sound is not as clear as i would like at higher sound levels.
it was my first time soldering , but i practiced first and i did a nice job imho. could bad soldering cause a bad connection? i twisted the wires , then soldered , but on a couple i got a little too much solder on them.
Modified by drewthomas14 at 2:47 AM 6/25/2004
Modified by drewthomas14 at 2:48 AM 6/25/2004
rfdphoto
Sep 11, 2012 02:39 AM
ray559527
Audio / Security / Video
Dec 30, 2011 04:54 AM
HtxPrelude2K
Aug 15, 2008 12:27 PM
orangegsr
Apr 20, 2004 09:41 AM
#1civicfan
Oct 1, 2002 02:23 PM
