keyless entry + car audio q's.
Old Jun 24, 2005 | 09:21 PM
ekcivic9's Avatar
Default keyless entry + car audio q's.
hello HT,
i have a 96 civic ex with keyless entry and cd (by the cup holders)...
i understand if i wanted to get an aftermarket headunit, id have to buy a special wiring harness and a dash kit.
could i just take out the cd player on the bottom? and hide the stock headunit somewhere in the center console (which ive read that has been done before)? would there be a nasty gap where the stock cd player was?
and on an ending note, i couldnt find any guides for a 96 ex w/ keyless and cd player... so im kinda clueless on how i would take everything apart.
thanks
Old Jun 25, 2005 | 06:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: keyless entry + car audio q's. (ekcivic9)
Go to http://www.installdr.com find your car, and you will have the info you need on removal, as for the CD, go to Honda or the bone yard and get the pocket that goes there. The door locks are a bit of a problem, but as you have already found out you can get a "T" harness that lets you leave the OEM radio in the car, [behind consol] and install the aftermarket Hu in the stock radio location, or leave the OEM radio in the stock location and mount the aftermarket HU down where the CD player was, [a little more work, for the front trim, but you should be able to mount the HU the same way the CD was mounted, ISO, [screws in the side] maybe a little filing] or, just get rid of all the OEM stuff, [radio and CD player] get the regular adpt. harness, and install an alarm and hook up the door locks to it or a key less entry module, [some for under $50] you could even get a cheap alarm and only wire what you need for the door locks to work. The only part of the OEM key less entry that is in the radio in the RF section. 94
Old Jun 25, 2005 | 03:26 PM
ekcivic9's Avatar
thanks for the info fcm... very much appreciated.
while this thread is here, would running 200watts to a 160watt rated sub be ok?
Old Jun 25, 2005 | 03:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">while this thread is here, would running 200watts to a 160watt rated sub be ok?</TD></TR></TABLE> Yes, it's better to be a little over powered then under powered. 94
Old Jun 26, 2005 | 10:07 PM
ekcivic9's Avatar
hold on...
if im understanding this correctly, i can just get a headunit and not deal with any wiring harness / din plate baloney if i just install in the current CD changer position?
can anybody verify?
will both headunits still have function?
i think i will opt for this option because it seems to be much cheaper. however, there are no directions for this &gt;.&lt;
Old Jun 27, 2005 | 07:36 AM
fcm's Avatar
fcm
Old Fart
You will still need the "T" harness, the stock HU will no longer work, [no sound, it's not hooked up to the speakers anymore.
When you pull the OEM CD out, you will see how to install the aftermarket HU, some mods will have to be done, they will be obvious 94
Old Jun 28, 2005 | 01:29 PM
ekcivic9's Avatar
Default Re: (fcm)
is the T harness you speak of located at crutchfield for 19.99?
would you recommend buying their instructions alsO?
Old Jun 29, 2005 | 07:44 AM
fcm's Avatar
fcm
Old Fart
I am not sure, have you got a link? There are a few, Scosche has 3 http://www.staub.ca 2 of them very expensive. What instructions? 94
Old Jun 30, 2005 | 01:40 PM
ekcivic9's Avatar
http://www.crutchfield.com/S-p...1720T
that one
Old Jun 30, 2005 | 04:50 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.crutchfield.com/S-p...1720T
that one
Yes, that is the Metra "T" harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">would you recommend buying their instructions alsO?</TD></TR></TABLE>
Old Jul 1, 2005 | 08:28 AM
ekcivic9's Avatar
crutchfield has a instructions for the specific car you are installing in... it tells you how to take apart the dash, etc...
i am pretty mechanically inclined, so i dont know if it s necessary or not.
Old Jul 1, 2005 | 10:05 AM
fcm's Avatar
fcm
Old Fart
You can get that info for free at http://www.instaldr.com or http://www.installer.com 94
Old Jul 2, 2005 | 04:33 PM
ekcivic9's Avatar
one last thing... the stock cd changer, is it a pain to get it out? i cant find any instructions on those also, will i need a din slot thing to take the place of the cd changer?
thanks a mil
Old Jul 3, 2005 | 07:25 AM
fcm's Avatar
fcm
Old Fart
It's no big deal to get the CD out, pull the console, and no you don't need the "din slot thing, [mounting sleave] with some modifying you will use the same system to mount the aftermarket HU as is used to mount the OEM CD changer, [ISO] machine screws into both sides of the unit. 94
Old Jul 3, 2005 | 11:11 AM
ekcivic9's Avatar
:thumbsup:
im still debating if i should use the stock headunit location for my new one and hide the old headunit, or just mount the new headunit where the cd changer is.
anyhow, fcm, thanks a lot for your help. once i get my paypal account up, ill give you some moolah for your troubles.
Old Jul 3, 2005 | 11:54 AM
fcm's Avatar
fcm
Old Fart
YW, and no "moolah" required 94
AllMotorBrew
15
Sep 18, 2007 05:44 AM
Spaceballsthelunchbox
Sep 17, 2007 09:18 PM
eg686
Mar 18, 2004 08:42 PM
AllMotorBrew
Audio / Security / Video
Oct 18, 2002 09:30 AM
civic-cpe
Aug 11, 2002 12:21 AM
