integra security
ive heard that it takes seconds to get into an integra with doing something through the window... anyone know this trick and if there's a way to stop it? what ways are there around master keys? what other common ways do thieves get in? a kill switch is great to keep your car, but then there's always the cd's, cd player, sub, etc.. how do you keep them out?
Best way is to get a 2 Way Alarm with paging Notification. There is nothing out there that can stop them from Trying but you can make it annoying for them.
1st thing : If you have Tinted Windows get a Glass Break Sensor
2nd Get a Dual Range Sensor (DEI's is called a 508D) What it will do is warn someone when they approach a vehicle that it is armed, by Chirping at them. Then it will also take care if anyone reaches there hands inside the vehile then it triggers the alarm.
3rd.. When you do the alarm have them hook up Starter Kill on the Alarm. This basically cuts all power to the ignition while the car is armed.
4th.. Get a Backup Battery Siren on your car's alarm also. Theives are realzing that if they cut the siren then no noise. But with a Back up Siren even with power disconnected from the Battery it will still sound.
thanks for that response, it motivates me to get a better alarm
as far as actually opening the door or trunk or something to get access into the car, is there anyway to make it harder for thieves? can i make a custom key lock for them, and is there something in the window that i can build to guard off from however they usually break in?
Gant
Audio / Security / Video
Jan 6, 2009 10:15 PM
