installing tweeters
Old Jan 1, 2002 | 04:32 PM
acuraLSSE95's Avatar
New User
Default installing tweeters
I have an integra with no tweeters on the door panal, I want to get a pair (which brand is good and how much?) and install them. how do I cut a small hole to fit them nicelly? how do I connect the tweeters to the existing door speakers? I need step by step info if you could write them down here.
thanks
Old Jan 1, 2002 | 04:49 PM
yellowbuffalo's Avatar
Default Re: installing tweeters (acuraLSSE95)
Im not sure how to connect them up to your factory radio. I have JL audio there awsome tweeters but there running from my amp Im using (not the reciever). Check out audio/security first.
Old Jan 1, 2002 | 05:03 PM
04accordV6's Avatar
Default Re: installing tweeters (slipknot23)
hmmm i plan on getting them where u people mount them besides door panels? I was think about putting it on top of the seat belt since i'm tall and it's a 4dr
Old Jan 1, 2002 | 05:31 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: installing tweeters (95integraLS504)
The purpose of tweeters is really to perfect imaging of sound. AKA surround sound. I put them in lots of kick panals and they sound great, not too sharp. Also I wouldn't recommend that you don't just add a tweeter to your stereo system cause it will not filter out enough low frequencies and will eventually blow the tweeter. I would instead buy an entire component system.
.02
[Modified by SuperSteve, 6:31 PM 1/1/2002]
Old Jan 1, 2002 | 06:41 PM
Brian_92GSR's Avatar
New User
You definately want a full component system. It will include new 6.5 inch (or whatever size fits) woofers that mount right in to where your old speakers were, as well as tweeters that can be mounted however you like. It should include two crossovers also - you hook them directly to your radio or amp, and they have outputs to go to the tweeter and woofer. It basically just splits the highs and lows.
thevirgin
Jan 13, 2008 05:05 PM
GraphiteMW
Audio / Security / Video
18
Dec 9, 2006 05:03 PM
Jose-aka-Pedro
12
Dec 5, 2006 05:40 AM
dgS2000
Honda S2000
83
Mar 24, 2006 05:37 AM
Kellindal
Jan 29, 2002 02:31 PM
