Install lock / Unlock on 2012 Odyssey
The wires are located at the 37P gray harness connector plugged into the driver's master window/door lock switch.
Lock and unlock are negative trigger.
At the 37P gray connector:
Lock is the pink wire at terminal no. 35.
Unlock is the brown wire at terminal no. 34. Unlock is the white wire at terminal no. 32. It requires a double pulse to unlock. Must use a diode isolate.
2011- Honda Odyssey Vehicle Wiring Chart and Diagram
