How to wire actuators to Compustar?
Old Apr 22, 2006 | 05:37 PM
Azxster's Avatar
Default How to wire actuators to Compustar?
For this model of compustar, I do not need relays right?
So I will use Method 3:
Yellow/Black + Green/Black are connected, but the diagram cuts out. Where does it goto?
Yellow + Green are connected, would it be powerful enough to do 2 actuators?
Yellow/White + Green/White are connected to fused 12V.
And another thing, my R500 will not deactivate passive. It responds to the command but still turns on passive.
Thanks a lot HT; my deck, alarm, amp/sub are installed cause of you guys!
Old Apr 23, 2006 | 12:05 PM
fcm's Avatar
fcm
Old Fart
Default Re: How to wire actuators to Compustar? (Azxster)
Do you already have power door locks in the car or are you adding them?
If you already have them, and the car is a Honda/Acura, "Method 1" is the one to use.
If you are adding power door locks, [actuators in each door] then "Method 3" is the one to use.
Yellow/black and green/black go to ground.
Yes it will do 2 actuators.
Either way relays are not needed, [they are built into the alarm brain]
I have contacted Compustars head office to see if they have an answer to the passive arming problem, I will let you know as soon as they get back to me. 94
Old Apr 24, 2006 | 05:58 AM
DireFire34's Avatar
Default Re: How to wire actuators to Compustar? (fcm)
i heard compustar sucks
Old Apr 27, 2006 | 06:03 AM
Flar's Avatar
Sorry for the somewhat threadjack...
If I wanted to wire a switch to control the lock/unlock of the actuators, that are wired using Method 3 above, where would I make the cuts?
Old Apr 27, 2006 | 07:03 AM
fcm's Avatar
fcm
Old Fart
Default Re: How to wire actuators to Compustar? (Flar)
You would have to install a DPDT switch on the 2 wires going to the actuator, or if you want to keep it low current and simple, install a set of off board relays for the actuators, like this... http://www.the12volt.com/doorlocks/page3.asp#arp change the wiring to "Method one" then all you need is a SPDT momentary low current switch where the common on the switch would go to ground and the other 2 wires would also go to the lock and unlock on the off board relays along with the lock and unlock from the alarm using "Method one", [neg. (-) trigger] . 94
ahhshietitztony
Audio / Security / Video
Jun 19, 2009 05:39 AM
patrick4588
Apr 29, 2008 12:53 PM
arbys2k
Honda S2000
May 5, 2006 02:07 AM
S1ERRA
Nov 18, 2003 01:50 PM
