How to install questions - dc5
How should I set up the power and grounds to the new subwoofer (basslink)?
Should I add another 8gauge amp kit or should I used the existing wire and have them both connected to one? Help a noob out.
Current Set-up:
-Alpine 4channel amp
-Alpine cda-7998
-eDi 6000s v.2 components(front only) https://honda-tech.com/forums/showth...351&highlight=
-8gauge amp wire kit
Adding:
Infinity basslink I
Current Set-up:
-Alpine cda-7998
Adding:
Infinity basslink I
thrty8street I would use at least a 10ga, maybe even an 8ga, the Basslink does not need a huge amount of current but it is a long run to the back of the car, the longer the lead is the thicker it needs to be and it can't hurt to install heavier gauge then needed. 94
Thanks. 8ga it is then.
Is there anything I can use for the battery terminals on the battery? Is it really safe to be running (2) 8ga power cables with fuses side by side?
Another question:
-Does the thickness of the ground cable have to be the same as the power cable? (for the sub that is)
There is no problem running extra power cables off the batt. as long as both are fused properly as close to, [but within 18"] to the batt. clamp as possible. 94
All I ever do is replace the stock clamp bolt with a longer one and add another nut so I have room for more then one ring terminal, I have also replaced the clamp with a "marine" type clamp and some times the "pimp my audio system" batt. clamps.
Thanks alot.
Would you recommend one of these?
http://www.optifuse.com/caraudiobattery.htm
[img]http://www.optifuse.com/images/GP-0130.jpg[img/]
If so is there a specific brand to get or place to buy them at? I am also planning on doing the big 3 later on prob in spring.
Yes, the ground should be the same gauge or thicker then the power cable.
The amp ground(s) should be as short as possible and both amps should be grounded to the same point if possible, as long as both leads are kept short.
I am no fan of "pimp my audio system" batt. terminals, or anything that uses set screws to hold cables in place, set screws do not make a very good connection. 94
wilaivue
Audio / Security / Video
Jun 4, 2010 04:57 AM
-iLLuZioN-B18C1
Dec 8, 2007 06:24 PM
Jose-aka-Pedro
Aug 16, 2006 01:26 PM
