how close can screen be to subs (magnet)?
Old Jun 16, 2005 | 01:52 AM
CrazyModGSR's Avatar
Default how close can screen be to subs (magnet)?
How close is too close? I am custom mounting a 17" screen in the rear of my Integra in the middle of two 12's, but kind of worried about the magnets screwing up the screen. Any comments? Edge of screen would be about 6.25" from the magnet of each sub. See front view shown below.
Thanks
Old Jun 16, 2005 | 09:32 AM
DJ Tussionex's Avatar
Default Re: how close can screen be to subs (magnet)? (CrazyModGSR)
You can tell when a screen is too close to a magnet because it will change colors. As long as it has a normal picture sitting between the subs you should be fine. Turning the tv on next to the magnets for a short period of time should not do permanent damage, move it away and turn it of and on and it should go back to normal.
Old Jun 16, 2005 | 02:25 PM
matt_in_sd's Avatar
If your screen is a flat panel type you shouldn't have a problem with the magnets causing distortion. But all of the vibration might bring a short life to the screen.
Old Jun 16, 2005 | 03:45 PM
dc24me's Avatar
if you are using a lcd screen, you are all set. you only need to worry about it if you have a cathode ray tube or old fashion tv.
Old Jun 16, 2005 | 08:02 PM
Goatsterrman's Avatar
Default Re: how close can screen be to subs (dc24me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">if you are using a lcd screen, you are all set. you only need to worry about it if you have a cathode ray tube or old fashion tv.
Yeah, if using LCD (Liquid Crystal Display) then there is nothing in the screen to be be affected by the magnets.
Fo-Do Fanatic
Audio / Security / Video
Dec 4, 2010 11:07 AM
Liquidgsr
11
May 20, 2006 12:40 PM
importdreamer
Jan 19, 2005 10:14 AM
Built B16A
Oct 4, 2004 11:47 PM
mrm1682
Apr 13, 2004 11:08 PM
