headlight wiring harness question
Old Nov 1, 2008 | 05:20 AM
H22CD7's Avatar
Default headlight wiring harness question
I was wondering if it is okay to use female spade connectors to wire your headlights instead of the wiring harnesses? I ask because I own a DA Integra and I switch back and forth between a set of JDM one pieces (H4H) for the summer and USDM 3 pieces (9007) for the winter. It would make things much easier if I could just plug the bulbs in with female spade connectors instead of having to deal with switching the harnesses everytime I switch the headlights. I figure it should be okay since all a harness is anyway is plastic holder for some female spade connectors. But I wanted to double check before I did this since I don't know too much about electrical stuff. So what do you think, will it be okay?
Old Nov 2, 2008 | 05:59 PM
95jdmej2's Avatar
Default Re: headlight wiring harness question (H22CD7)
I have done it, it works, looks like ****, but works. If your going to do it that way, i would make sure the connectors are insulted. But you could always buy a h4 harness from passwordjdm for less than $20 and you could make a conversion harness so unplug it that way and it looks cleaner. Cleaner is always better.
Herr Oberst
Honda Civic (2001 - 2005)
Nov 2, 2013 03:20 PM
H22Ej1
26
Mar 12, 2008 06:56 PM
daluv
Jan 17, 2008 11:31 PM
g0tgot
Jul 28, 2007 06:11 AM
integracura
Jun 13, 2007 04:49 PM
