hardwiring radar detector
Old Sep 12, 2005 | 02:05 PM
phoshizzle88's Avatar
Default hardwiring radar detector
i was thinkin about hardwiring my radar detector to a switch. if i was gonna run the power from the fuse box under the dash how would i do that?
Old Sep 12, 2005 | 03:56 PM
zumiez007's Avatar
Default Re: hardwiring radar detector (phoshizzle88)
It's not that hard. You don't even need to go to the fuse box. You can just use a relay and wire it to go on when the ignition is on.
Old Sep 12, 2005 | 04:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: hardwiring radar detector (zumiez007)
You don't even need the relay, there is a 2nd ign. free pin on the in car fuse box, use it. 94
Old Sep 12, 2005 | 09:26 PM
Default Re: hardwiring radar detector (fcm)
what does the 2nd ign look like
Old Sep 13, 2005 | 12:07 PM
fcm's Avatar
fcm
Old Fart
On the fuse box you will find 3, 4 or 5 free pins, depending on car, they are male flat spade term. (250) the same size as the pos. (+) term. on most speakers. here is a pix of them on a g2, scroll down till you see it, the free pins are just above the fuses http://www.g2ic.com/forums/showthread.php?t=101440 there will be a 12V+ constant, a 12V+ acc.. a 12V+ 2nd ign. and a 12V+ parklight output/input. 94
Old Sep 13, 2005 | 05:53 PM
JDM_EM1's Avatar
i spliced mine into my cigarette lighter, the hardest thing was running it down from the top of the dash.
Old Sep 14, 2005 | 09:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: hardwiring radar detector (JDM_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">i spliced mine into my cigarette lighter, the hardest thing was running it down from the top of the dash.</TD></TR></TABLE> And that would work also, but it would also be on when the key is turned onto acc., The point I am trying to make is, why cut/splice into anything, [and add load] when Honda/Acura went to the trouble of giving you the free pins, so when you need to add things, you have a place to get power without adding extra load to an existing circuit or having to "splice". eg. Would you wire up, [splice in] a trailer plug into the wiring at the back of your car when most Honda/Acuras come with a place to plug the trailer plug adpt. into. 94
Old Sep 15, 2005 | 04:56 AM
JDM_EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> And that would work also, but it would also be on when the key is turned onto acc., The point I am trying to make is, why cut/splice into anything, [and add load] when Honda/Acura went to the trouble of giving you the free pins, so when you need to add things, you have a place to get power without adding extra load to an existing circuit or having to "splice". eg. Would you wire up, [splice in] a trailer plug into the wiring at the back of your car when most Honda/Acuras come with a place to plug the trailer plug adpt. into. 94</TD></TR></TABLE>
i know about those i just dont know how to use them. i heard you have to put a fuse in to get them to work, i've tried using them on other things i installed but i cant ever get them to work??
Old Sep 15, 2005 | 09:47 AM
fcm's Avatar
fcm
Old Fart
i know about those i just don't know how to use them. i heard you have to put a fuse in to get them to work, I've tried using them on other things i installed but i cant ever get them to work??</TD></TR></TABLE> Then you are doing something wrong, in our shop we use them all the time, as for the fuse, you don't have to install a fuse for them to work, you should install the proper fuse for what you are powering up when using the free pins, [that would be an in-line fuse]
But like I said your way works just as well, my way is just a little cleaner. 94
Garebears
Mar 3, 2015 06:10 PM
aasarsak
Sep 18, 2010 04:38 PM
tempsohc
Sep 15, 2009 08:31 PM
O2DAB05
Jul 10, 2009 06:11 AM
racecarpete
Audio / Security / Video
Mar 30, 2003 07:44 PM
