grounding kits and voltage stabilizers... why?
Old Nov 23, 2010 | 04:16 AM
delta25's Avatar
Default grounding kits and voltage stabilizers... why?
I'm considering upgrading my "big 3" wiring in my car (98 civic). However, I see alot of engine ground wire kits and voltage stabilizers on the market. So my questions are:
1) Is it worth having a VS, or is it tuner bulls**?
2) Does a ground wire kit make a difference?
3) Is a ground wire kit still functional if the "big 3" wires are swapped to 0 gauge?
Old Nov 23, 2010 | 07:04 PM
joeymc13's Avatar
Default Re: grounding kits and voltage stabilizers... why?
grounds make a positive difference, whether or not you have upgraded the big 3. The larger the wire, the less resistance to ground, so 0 awg wont hurt anything. I dont understand your question #3... If you swap to 0 awg, is that not the ground update kit you are referring to in the first place? I don't have an opinion on VS, I don't see an immediate benefit, nor do I see a negative on them.
Old Nov 23, 2010 | 07:27 PM
Cobb2819's Avatar
some performance companies make all kinds of "ground kits" that are basically a bunch of little grounds hooked up to a ground distribution block.
as for the question...start with the big three.
Old Nov 24, 2010 | 12:45 AM
delta25's Avatar
yes i am, to refine #3: i guess i'm asking if once i upgrade to 0 gauge, is it still beneficial to have a ground wire kit? if the engine already has a 0 gauge ground wire on it?
Old Nov 24, 2010 | 12:56 AM
Eran's Avatar
HT White Ops
Interesting story about grounding kits:
When I was a ricer, I did a grounding kit on my car. Made them with gold connectors and 0awg wire. And you know what? It made a difference I could feel. Idle was more stable and acceleration was improved.
Later, when I was done having red wires going everywhere in my engine bay .... I bought brand new grounds from Honda. Replaced all the 0awg grounds, and goddamnit if I didn't notice a bit of difference.
Lesson learned: I was a ricer and your stock grounds get corroded and nasty. Butt dyno does not equal power.
lmiguelvv
Jul 30, 2004 12:18 PM
pearlteg
Apr 17, 2004 10:52 PM
splinter51
12
Apr 12, 2004 07:33 PM
joeski
Apr 10, 2003 12:58 PM
