Firewall
Old Jan 24, 2002 | 12:19 PM
Hoagieryder's Avatar
Default Firewall
I have a 95 integra gsr are and I am installing a new amp. Where is the best place to go through the firewall?
Old Jan 24, 2002 | 12:56 PM
justinCO's Avatar
Default Re: Firewall (Hoagieryder)
On my 2001 GSR there is a small hole just below and to the right of the battery (if you're looking at the car from the front). It is plugged with a rubber gromet but I just cut an X in it and pushed my 4gauge wire through and then sealed it with some rubber weatherproof sealer gunk I imagine your Teg would have a hole in the same spot.
Justin
Old Jan 24, 2002 | 03:38 PM
G_S_R's Avatar
Default Re: Firewall (justinCO)
I ran my wires through a grommet by the brake fluid reservoir. be very careful when cutting through it. lotsa wires.
Ron
Old Jan 25, 2002 | 06:56 PM
Weston's Avatar
I just drilled a hole in the firewall between where two cables go through. It's a bit hard to explain, but there's these two cables that run through the firewall, each in their own hole. They are next to each other but have some space between them.
They are on the driver's side of the car and you can see them from either the engine compartment or if you look above and behind the gas/brake pedals. I think one of the cables is for the gas pedal, and the other may be for either the clutch or brake. I just drilled a small hole in the space between them, stuck a grommet in there (bought some at Radio Shack), and ran the wires through. This was for my alarm install, so that may or may not be a great location for your setup.
Old Jan 27, 2002 | 09:28 PM
cam003's Avatar
i have a 95 GSR and i went through the fire wall just under the battery and a little to the right.
Ochem2012
Aug 31, 2004 10:06 PM
CrazyModGSR
Aug 20, 2004 09:49 AM
95lsinteg
Dec 1, 2003 12:29 PM
kulu
Audio / Security / Video
Jul 12, 2003 07:38 AM
TrikMeister408
Nov 27, 2002 06:27 PM
