finally started my new system!
Old Nov 13, 2003 | 10:53 AM
GroundZer0 336's Avatar
Default finally started my new system!
ok i ordered 2 15inch rockford punch hx2's. i plan on making a 6ft3 enclosure tuned at 30hz for my crx. and run 500wrms to each sub.
im going to use round ports, but does the placement of the port matter as long as its on the same plane as the subs (so tehres no cancellation) like if i put the subs on one end and the ports on the other end far away from the subs? or should i put them right at the subs.
Old Nov 13, 2003 | 06:32 PM
vteg's Avatar
New User
Default Re: finally started my new system! (lowlife4life)
It does not matter too much. Which ever is easier, or looks better to you. Keep the ports a few inches from the walls and you should be fine.
Old Nov 15, 2003 | 07:09 PM
Default Re: finally started my new system! (vteg)
i was thinking of making the enclosure w/ 2 chambers. since im only going to have one of the subs for now i was thinking i would just do that and put it in one of them for now. would it be better if i had a single chamber or 1 for each sub. since im using round ports they shouldnt change should they?
Audio / Security / Video
11
Jul 7, 2007 11:50 PM
Trustfall990
Nov 17, 2005 04:46 PM
Newbsauce
13
Aug 1, 2005 10:26 AM
jweller
15
Dec 23, 2004 10:09 PM
jamal-188
12
Dec 11, 2001 04:23 PM
