external crossover placement-does it matter?
I have an older set of Alpine TypeR components and they have an external (adjustable) crossover.
I have a temporary setup with the crossovers mounted just off my amp in the trunk that I am going to run new wires to the doors with. Am I going to notice having this placement over say having the crossover mounted on the door? I have a few suspicions but i want to hear some oppinions from a SQ POV. Matt |
Re: external crossover placement-does it matter?
With the proper gauge wire you will be fine.
Originally Posted by HellaFab
(Post 46859972)
I have a temporary setup with the crossovers mounted just off my amp in the trunk that I am going to run new wires to the doors with. Am I going to notice having this placement over say having the crossover mounted on the door? I have a few suspicions but i want to hear some oppinions from a SQ POV. Matt If it were me I wouldn't care. |
The closer to the speakers, the less wire you'll have to use. My infinity crossovers are mounted directly to my door metal (on the outside, so they aren't dripped upon.)
I usually have the crossovers mounted on the door but in a dry location. You don't want get those things wet (no pun intended).
Originally Posted by joeshmo
(Post 46862911)
smaller gauge wire? |
Originally Posted by kecknj
(Post 46890607)
:thud:
smaller gauge wire? If you put the x-overs in the trunk, you'll have to run two sets of wires to each door, as opposed to the one set needed if you put the x-overs up front. |
doesn't really matter in the realm of things..just keep them safe and away from water.
Door treatments, speaker placement, and power play a much larger role in sq. |
(Post 46896786)
What are you talking about?
If you put the x-overs in the trunk, you'll have to run two sets of wires to each door, as opposed to the one set needed if you put the x-overs up front. just joking you man! clearly if you mount something closer, it will use less wire. it was like saying if something is smaller it takes up less space. sounds funny, no? |
(Post 46945134)
got it. plus you use smaller gauge wire.
it doesnt matter...
| All times are GMT -8. The time now is 12:20 PM. |
