EG hatch CD player install/kit
Old Mar 26, 2010 | 10:10 PM
s13hero's Avatar
Default EG hatch CD player install/kit
So I feel dumb for asking this but I'm finishing up installing a CD player in my EG hatch and it comes with a small flat metal bar to bend and drill somewhere to secure it and I was wondering how/where everyone else secures their cd player in their hatch because right now it will just slide out if you push it from the back.
Old Mar 26, 2010 | 10:12 PM
speedooo's Avatar
Default Re: EG hatch CD player install/kit
thats how i always leave my cd players. makes for easy access later on
Old Mar 29, 2010 | 07:38 PM
s13hero's Avatar
I have the din "cage" in the dash but the cd player doesn't secure into the cage well, it did when I took it out of the box, but when I took the cage off the cd player and put it into the dash then put the cd player back in it still slides out, so I was wondering if I need a new cage where can I get one, are they all the same or what?
Old Mar 29, 2010 | 11:42 PM
speedooo's Avatar
A metal strap bolted to the cd player at one end and bolted to the anchoring point of the stock tape deck is your best bet..its never going to sit perfectly.
But honestly, you're going to need to get behind it at some point in time and these measures are just going to make the whole process really frustrating.
Old Mar 30, 2010 | 06:25 AM
fcm's Avatar
fcm
Old Fart
Mount it to the same place as stock HU is mounted, [rear support brace] Honda, in their great wisdom, put a hole in the center of the rear brace so installing a rear support bracket for aftermarket HUs is easy as pie.
Bend the strap into an "L" bracket so it is level with the bottom of your HU, a blot/screw through the rear support bracket into the L bracket will support/brace your aftermarket HU.
This may help... http://www.installdr.com/InstallDocs...PDF/466017.pdf step 1 and 3 will show you the rear support brace and back of stock HU. 94
hybrid90
May 6, 2014 07:35 AM
jdmcd7_cali-luv
Dec 19, 2008 02:05 PM
dafranchise69
Oct 21, 2005 08:21 AM
