dynomatting sidepanels...?
Old Mar 20, 2003 | 02:05 PM
sydacheck's Avatar
Default dynomatting sidepanels...?
has anyone gotten their sidepanels dynomatted (extreme)? if so, was it worth it? and what other parts of your car have gotten dynomatted?
Old Mar 20, 2003 | 02:20 PM
t0p_sh0tta's Avatar
Default Re: dynomatting sidepanels...? (sydacheck)
I did everything but the roof, and it was worth it. It wouldn't be if I used dynamat though, that stuff costs an arm and a leg.
Old Mar 20, 2003 | 02:21 PM
jolt-tsp's Avatar
I have a 1997 civic hx, and I covered nearly my whole back end in dynomat extreme.
I removed all panels and the rear seat. I drove it around to see how loud it was. It was loud.
I then used dynomat extreme and covered nearly every inch, then drove it around. There was a difference, but not a $300 difference.
Then I went out and filled my rear quarterpanels with Great Stuff I think it is (The insulating foam they use on houses when they drill holes from the outside to the inside through vinyl or brick). For about $20 I was able to fill both quarter panels, that did 5x what the dynomat did, and probably weighed about the same.
I then went to put my rear interior back in, but had to stop and see a movie first. When I got out of the movie, my car was gone . So I never got to test it with the interior in. I'd have to say the canned foam insulation from home depot is a better product than dynamat.
Old Mar 20, 2003 | 11:22 PM
Broman78's Avatar
Default Re: dynomatting sidepanels...? (jolt-tsp)
just use peel and seal can get it at lowes or HD for about 30 bucks an 50 foot roll.
Old Mar 21, 2003 | 02:25 AM
1BlackHatch's Avatar
Dynomat and foam do two different things. Dynamat is designed to deaden panels so they don't vibrate. The foam is designed to dampen sound which can be used for road noise.
Old Mar 21, 2003 | 09:14 AM
t0p_sh0tta's Avatar
Default Re: dynomatting sidepanels...? (Broman78)
Peel & seel is too narrow, look for something wider if your going to be doing large areas. You'll need several rolls of this if your planning on going all out. $$$$
Old Mar 21, 2003 | 10:41 AM
loki2323's Avatar
Default Re: dynomatting sidepanels...? (t0p_sh0tta)
narrow as far as thin? or narrow as far as width?
they well it:
9 x 33 1/2
12 x 33 1/2
18 x 33 1/2
and I also think the guy said they have a roll larger than that..the 18 x 33 1/2 is 61.50 a roll....still pretty decent
Old Mar 21, 2003 | 11:00 AM
t0p_sh0tta's Avatar
Default Re: dynomatting sidepanels...? (loki2323)
Narrow in width. The roll that I have is only 6 inches, and I've never seen a wider one. Most other materials come in atleast 1 foot wide rolls.
Old Mar 21, 2003 | 11:09 AM
loki2323's Avatar
ahhh ok yeah the roofing supply company by me has the rolls in different widths
I am thinking of buying it in the 18 x 33 1/2 rolls
should make it easier since the sheets are wide...any wider and I think I would end up with a lot of scraps when cutting
Old Mar 21, 2003 | 12:07 PM
JOMO
Guest
Posts: n/a
18 inches is wiiiiide!!!!! i get mine 12 inches long, sold by the square foot seemswide enough to me, and dirt cheap
Old Mar 21, 2003 | 12:26 PM
loki2323's Avatar
Default Re: dynomatting sidepanels...? (JOMO)
true...but remember its for roofing...so they sell rolls that are even wider than 18
Old Mar 21, 2003 | 03:46 PM
t0p_sh0tta's Avatar
Sounds good to me. You'll need a few scraps anyways.
Old Mar 21, 2003 | 05:19 PM
JOMO
Guest
Posts: n/a
i melt my scraps and....never mind
Old Mar 21, 2003 | 06:52 PM
koco's Avatar
I bought peel & seal in a 12" wide roll. They also offer 4" width for seams. I found 12" width to be easy to work with.
Old Dec 15, 2008 | 04:48 PM
slowturbocx's Avatar
how well does it(peel and seal) work? does it work well in the cabin of the car? how about the doors?
Old Dec 15, 2008 | 06:18 PM
sqsi's Avatar
You revived a pretty old post, but to answer your question peel and seal is not worth using
redhondacivic
Jun 18, 2006 08:56 PM
red_honda_racer
Jan 15, 2004 01:09 AM
4doorH22
Sep 4, 2002 03:36 AM
4doorH22
Sep 2, 2002 11:40 AM
