dynomat box
Actually both the above are wrong, Dynamat will dampen anything it is applied to, apply it to the inside of the box for dampening and sealing.
I will also laminate Dynamat between 2 sheets of 3/4" MDF for custom, high power, sub cabinets. 94
That must have been one big s.o.b.
Sorry, got pix, lots of them 12 big photo albums plus a big box full of slides [35mm] they tend to accumulate after 35 years, no way to scan and post them.
Time to replace the Nikon SLR with one of them there new fangled ones.
94
94
I've never bothered. IMO, a spec-built, properly sealed enclosure is sufficient for the average system. I've used polyfill in some applications, but not as a standard. MDF is already very non-porous (compared to junk like particle board) and quality sub baskets are made to eliminate unwanted resonance(s)
I dunno. Maybe if I heard it for myself, I wouldn't be a naysayer. For schitz 'n' giggles, I may try it with some leftovers. There's only one way to be certain.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
It really works. It takes the ping or hollow sound out of certain types of enclosures and sub types. If you do the whole inside. Works great on band pass enclosures.
You want some "schitz 'n' giggles" if your current sub cabinet is not "sealed" and no matter how well constructed it is, pull the sub(s) "paint" the inside with fiberglass resin, 3 coats min., reinstall sub(s) and have a listen, then pull the sub(s) again and install the Dynamat, reinstall the sub(s) and listen again.
I bet you a dollar you will never build a box again without at least "sealing" it.
94
I realize MDF is porous, but I was comparing it to particle board. (which is junk) When I said properly sealed, I was referring to what you're talking about. I used two coats of some cheap roll-on bed liner, though. Why? Because I had some.
It's a PITA to pull the enclosure out, but I'll eventually get around to it and give the ol' Dynamat a try.
Who told you that? MDF is porous....Try to find any RF Top Gun videos of the the shop
vac picking up 2 pieces of supposed non porus mdf.
I have seen it done in SPL enclosures/vehicles, never thought of trying it in a vehicle thou, weight is one thing that comes to mind.....
Kirk R
(sarcasm) It was strictly a competition bit, though. He didn't really drive it.Edit:
Originally Posted by audioroach
Dynaboard is making a comeback....
Last edited by It Wasn't Me; Dec 17, 2008 at 08:16 PM. Reason: existential inquiry
