dvc wiring
Old Nov 1, 2002 | 01:17 PM
101998's Avatar
Default dvc wiring
I currently have a fosgate he2 10" with a 4ch fosgate amp (500x), its currently set up w/ one side bridged running 2ohm into the sub and then the other 2 channels are set up for my front mids-highs. Problem: The damn thing keeps over heating, is there a way to wire a dvc to 4ohms and still run both coils, or mabey a way to keep the amp cooler, its currently mouted on the box (in the trunk).
Question I am exentually going to get a second amp should I get another 500x fosgate and bridge one side for each coil, or get the two channel (500s) and continue 2ohm operation?
Old Nov 1, 2002 | 09:10 PM
incubus's Avatar
Default Re: dvc wiring (audiobahnman)
u r screwed u can either run ur he2 in a 2ohm load or in a 8ohm load. this is why I think rockford should have made them in dual 2ohm vc also.
if u get another amp which would be the intellegent thing, get another 500x and bridge the 4 channels to 2. this will keep the sub running in a 4 ohm.
remeber if u bridge an amp it sees half the load that the sub(s) sees (ie: sub sees 4 ohms, amp sees 2 ohm). if u run the 500s in "two ohm" it will actually be seing a 1ohm load which is below rockfords range of acceptable impedance.
500x no question.
Old Nov 3, 2002 | 06:01 PM
101998's Avatar
Default Re: dvc wiring (incubus)
should have realized the resistance cut by bridging, thanks for the advice
Old Nov 3, 2002 | 06:11 PM
GSteg's Avatar
u can just run 1 coil and leave the other unhooked. that should give you a 4ohm load.
Old Nov 3, 2002 | 07:05 PM
CovertFI's Avatar
Default Re: dvc wiring (GSteg)
why dont you just add a fan and see what that does so you dont have to fork over extra money for another amp
Old Nov 3, 2002 | 08:20 PM
101998's Avatar
Default Re: dvc wiring (CovertFI)
I wasn't aware you could put fans on fosgate amps. Do you know where I could pick one up?
Old Nov 3, 2002 | 08:47 PM
GSteg's Avatar
i think you would have to make a custom amp rack. there are no slots on the rockford amp to do so.
Intrepidv614
Audio / Security / Video
Dec 13, 2005 05:02 PM
ctownintegra
Oct 29, 2004 07:57 PM
Mazzazx51
May 19, 2004 05:55 AM
GroundZer0 336
20
Aug 30, 2003 04:27 AM
vtec-outlaw
Feb 4, 2002 12:45 PM
