diy alarm
i recently bought an alarm off of ebay (cheap) just to discourage and wondering if anyone has done a 92 civic lx before and if there are any tricks or tips or anything like that
thanks
thanks
No tricks or tips really....its a pretty straight forward easy install unless you are hooking up locks. Heres the wiring info...kinda messy since I copy and pasted it. hope it helps:
12volts white + brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Second Starter
Ignition black/yellow + brn conn abv fusebox
Second Ignition
Third Ignition
Accessory yellow + brn conn abv fusebox
Second Accessory
Keysense
Power Lock green/white - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
Power Unlock green/red - in drivers door
Lock Motor
Unlock Motor
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Notes: the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer blue AC 2-pin plug near distr.
Notes: Also at round gray connector next to hood strut.
Wait to start
Brake Wire green/white + brake pedal switch
Parking Brake
Horn Trigger blue/green - steering column
Notes: can also be found blue/red at anti-theft if equiped
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
ussop
Audio / Security / Video
Mar 13, 2015 11:36 PM
canucker
Nov 9, 2008 09:24 AM
EnjoyTheRideDC2
Jul 1, 2004 09:17 AM
