Del Sol Install Problem
I have a 93 del sol, and my car came with an aftermarket deck just sitting in the hole. I havent had much luck finding a mounting kit for this car (since its really just a DIN opening) Has anyone got any ideas?
There is no kit, only a wiring harness adapter, you use the oem radio mounting kit, and unless the last owner did not reinstall it after removing the oem HU it should be there, if not your going to have to make a trip to the bone yard, you may still be able to get the 2 parts, [plastic trim and metal mounting bracket] from Honda.
This will give you a better idea of what you are dealing with... http://www.installdr.com/Insta....html
Hope this helps.
94
Hope this helps.
94
