deck security
Old Nov 1, 2005 | 09:45 AM
suzuki515's Avatar
Default deck security
i kno theres no real way to keep them from stealing your deck if they get into your car, and i kno theres ways to slow them down. i heard somewhere to use all different screws to slow them down, so what else are you guys doing to secure your decks. i heard about something called a backstrap or something like that and i couldnt find it when i searched
Old Nov 1, 2005 | 09:54 AM
.spicoli's Avatar
Default Re: deck security (suzuki515)
i;ve heard of people putting razor blades down the sides so when the theives try to grab it the get a rather painful suprise
Old Nov 1, 2005 | 10:48 AM
MLD211's Avatar
You notice how when you buy a deck there is a threaded hole in the center of the back of the radio. The radio come whith a screw that fits this hole. Use a back strap, which comes with most radios its the strip of metal with a bunch of holes in it, use the scre provided to secure one end of the back strap to the deck and then secure the other end to somthing solid in the car once the radio has been mounted.
Old Nov 1, 2005 | 10:55 AM
suzuki515's Avatar
Default Re: (MLD211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLD211 &raquo;</TD></TR><TR><TD CLASS="quote">You notice how when you buy a deck there is a threaded hole in the center of the back of the radio. The radio come whith a screw that fits this hole. Use a back strap, which comes with most radios its the strip of metal with a bunch of holes in it, use the scre provided to secure one end of the back strap to the deck and then secure the other end to somthing solid in the car once the radio has been mounted. </TD></TR></TABLE>
oo i get it, so the back strap will be a pain in the *** to get unscrewed if they're stealing it, like its hard to get tools in that small space to unscrew a backstrap
Old Nov 1, 2005 | 01:54 PM
MLD211's Avatar
yeah pretty much, if you do it right the deck wont budge even a little bit. The thief would have to disassemble a bunch of panels and what not to find the other end of the back strap and get the screw out. This can be bad in the sense that the thief may do a bunch more damage to your car trying to remove the radio than radio even cost you to begin with.
Old Nov 3, 2005 | 11:04 AM
onegreedy's Avatar
Default Re: (suzuki515)
also the back strap helps keeping the stereo stable and not vibrate
Old Nov 3, 2005 | 11:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: (onegreedy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onegreedy &raquo;</TD></TR><TR><TD CLASS="quote">also the back strap helps keeping the stereo stable and not vibrate</TD></TR></TABLE> Absolutely..... Ditto that, if you want the CD transports suspension to work properly you need to install a proper back support. 94
20strong
Honda Civic (2006 - 2015)
May 2, 2007 10:54 PM
J.nguyen
Apr 4, 2007 07:42 AM
againstme
Mar 16, 2006 08:41 PM
pousevrika
Audio / Security / Video
Nov 8, 2004 07:45 AM
00VTEC
Sep 24, 2002 06:58 PM
