.....Compustar 2WSS-AS question....
Old Oct 28, 2007 | 06:24 AM
skn181's Avatar
Default .....Compustar 2WSS-AS question....
Does the Compustar 2WSS-AS work for both automatic and manual transmissions?...or is there a specific version for manual and a specific version for auto's? I am having a hard time finding the Compustar 2WSS-AS for a manual transmission. The ones that I find on ebay say that it is for auto's only. Even though they state that it is for automatics, can it still be used on a manual transmission? Does it make a difference? Thanks!
Old Oct 28, 2007 | 09:31 AM
fcm's Avatar
fcm
Old Fart
Default Re: .....Compustar 2WSS-AS question.... (skn181)
All Compustar remote starts work on both standard and automatic transmission cars, they all come "programed" for standard transmissions, you cut a jumper for automatic transmissions, see jumper just above DP1 and DP2 on wiring diagram...
http://www.staub.ca/tech/Manua...l.pdf
The ones you see on eBay are recalls, recall and sold for salvage, they had a glitch in the reservation mode, [for standard transmission] so Compustar recalled the defective ones, sold them for salvage of parts, buyer turns around and sells them on eBay as for automatic transmission only models.
BTW eBay is not where you want to buy an alarm, you do not know what you are getting, [recalled, refurbs, or even fakes] and you will have no manufacturers warranty or support. 94
Old Oct 28, 2007 | 09:48 AM
nsxxtreme's Avatar
Default Re: .....Compustar 2WSS-AS question.... (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">All Compustar remote starts work on both standard and automatic transmission cars</TD></TR></TABLE>
Not necassarily true. I purchased one of these so called alarms from a member on this forum and it was indeed set to only an automatic or manual. It took me over 5 months to sort the issue out and get the correct alarm. By that time I had the correct alarm I had no use for the alarm.
Make sure you buy one that is specific to your needs.
Old Oct 28, 2007 | 04:01 PM
skn181's Avatar
What would be the average cost of the unit and installation from a compustar dealer?
Old Oct 29, 2007 | 06:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: .....Compustar 2WSS-AS question.... (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Then the member is cutting the loop or he got a special order from Compustar, the chain I worked at did that, and got a Compustar for manual transmissions only, loop was not installed, it was a trace on the circuit board instead, I have cut the trace to make it for an automatic more then a few times, [customer gets new car].
Jumper Wire
On Uncut: Manual Transmission
Off Cut: Automatic Transmission
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skn181 &raquo;</TD></TR><TR><TD CLASS="quote">What would be the average cost of the unit and installation from a compustar dealer?</TD></TR></TABLE> MSRP for the 2WSS-AS is $599.99 US, it includes basic install.
Old Oct 29, 2007 | 09:30 AM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Then the member is cutting the loop or he got a special order from Compustar, the chain I worked at did that, and got a Compustar for manual transmissions only, loop was not installed, it was a trace on the circuit board instead, I have cut the trace to make it for an automatic more then a few times, [customer gets new car].</TD></TR></TABLE>
My understanding was this is what he thought as well. But it turned out to not be the case. I think Compustar just ships out what they have at that momment.
My only comment here was for the OP to make sure that this loop is there before purchasing the alarm. Insist that the person you buy it from take it out of the box and look. Compustar is extremely slow at getting units returned back to you.
Old Oct 29, 2007 | 10:49 AM
fcm's Avatar
fcm
Old Fart
Maybe it's a USofA thing, all Compustar remote starts we get come with loop, [or trace] intact, for standard transmission application, we have to cut the loop, [or dremel the trace] for automatic transmission application.
Even when you check the site, there is no model number for one that is for an auto and another one for standards, the brains are the same, with factory default for standards 94
mjgregg69
Honda CR-V & Element
Apr 30, 2020 07:37 AM
vshavoc
Apr 8, 2009 03:51 PM
pr93eg6
Mar 26, 2006 09:20 PM
My ID says Jeff
Apr 13, 2004 12:17 PM
bangedupdx
Mar 31, 2003 10:17 AM
