clarion deck wont power on in my eclipse
Old Jan 18, 2002 | 11:31 AM
FusionITR's Avatar
Default clarion deck wont power on in my eclipse
---this is in the eclipse not the R---
i was installing a clarion db315 in my 1g yesterday, i hook up everything right and the deck doesnt power on! Whats the problem? Its not the fuse on the deck or the fuse on the car, if i put in the stock deck it works fine but when i put in the clarion db315 it doesnt power on. Does it have something to do with the small plug that looks like the antenna connection (im guessing its ground)? cause i notice when u hook up the stock deck it doesnt power either until u plug it in. Theres no plug for it on the clarion db315 but when i touch it to the deck it still doesnt power on.... anybody know what the problem is???
Old Jan 18, 2002 | 01:54 PM
Phat Corolla's Avatar
New User
Default Re: clarion deck wont power on in my eclipse (FusionITR)
Man, I'd love to help. If I could see it, I guarantee I could fix it in minutes. Unfortunately, I can't picture the problem from what you're saying. I'll do some thinking, and if I get anything, I'll post it. Good luck!
Old Jan 18, 2002 | 02:10 PM
FusionITR's Avatar
Default Re: clarion deck wont power on in my eclipse (Phat GS-R)
ill post pictures when i get off work
Old Jan 18, 2002 | 02:11 PM
New User
That could certainly help. I'm also at work. It's nice to have nothing better to do every once in a while than surf Honda-Tech. He He.
Old Jan 18, 2002 | 02:15 PM
FusionITR's Avatar
i have honda-tech open all day while im at work
Old Jan 18, 2002 | 08:03 PM
95CoupinIt's Avatar
u need to ground the wire from the clarion if i recall correctly from my previous install experience..there is no ground in the mitsu harness..this should solve ur problem...let me know how it goes...
B.J.
email me at bjsguitar@aol.com with any questions.
Old Jan 19, 2002 | 05:25 AM
redblues's Avatar
New User
Find a screw on the chassis of the HU and wire that to a ground. The antenna lead also grounds the unit if you connect it, but tends to introduce ground noise.
I had the same problem on a Mazda.
Old Jan 19, 2002 | 06:05 PM
ooostenb's Avatar
the antena has to be pluged in for it turn on. if u touched the antenna to the chasis while the radio was on, you most likely fried that radio.
Old Jan 19, 2002 | 06:50 PM
CanadaCivicSIR's Avatar
New User
Default Re: clarion deck wont power on in my eclipse (ooostenb)
Just to let you know you have to hook up the ground wire of the clarion deck to ground on the chassis somewhere. Mitsu did not have a ground wire in the factory harnesses.
Old Jan 20, 2002 | 06:57 AM
Eric R's Avatar
Default Re: clarion deck wont power on in my eclipse (CanadaCivicSIR)
That's right!
And remember: Always make the ground first.
AccordDrivah
Mar 25, 2012 07:24 PM
russell707
Apr 26, 2010 04:33 AM
EF9*Hottie
Nov 7, 2007 02:00 PM
Blanket Jackson
Audio / Security / Video
Jun 9, 2007 05:30 PM
fidiv
May 12, 2006 05:27 PM
