civic speaker install
Old Dec 14, 2006 | 03:26 PM
turnsignalandy's Avatar
Default civic speaker install
So I got some new pioneers to replace my front speaker.When i took the stockers out, they had this small white two piece plug. Does that plug do anything besides allow the stock speaker to separate from the harness? Also how should i wire my new ones, before or after the plug?
Old Dec 14, 2006 | 05:53 PM
White95SiHB's Avatar
Default Re: civic speaker install (turnsignalandy)
You can get a speaker harness adapter. The white plug will plug into the adapter, which has 2 wires (+/-) which in turn connect to the speaker.
Another way to do it is to pry open and unsnap the white plug, separate the female spade connectors from the plug and in turn connect them to their respective (+/-) male spade on the speaker.
I have done both methods on my 1995 Civic.
Old Dec 14, 2006 | 05:57 PM
Default Re: civic speaker install (White95SiHB)
wat if i do the following. Cut the wire in between the stock speakers and the plug, then hook up my poineers from the place i just cut.
Old Dec 14, 2006 | 07:02 PM
SteveoBA8's Avatar
Cut the oem speaker connector off/ crimp cap,butt connect,solder new speaker wires that came with speakers.
Old Dec 15, 2006 | 10:48 PM
TheBob's Avatar
yep just cut the plastic connector off and hook the wires to the speakers like previously stated.
ninty1civic
Nov 11, 2009 11:33 PM
93civicexthug
Mar 23, 2007 02:20 PM
DA is best
Apr 19, 2006 11:01 PM
jerbear!
May 9, 2005 02:47 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
