Cannot recieve Radio Stations
Old Jul 24, 2004 | 06:42 PM
Cominom's Avatar
Default Cannot recieve Radio Stations
I have a 2002 Honda Civic and I just installed a Sony CDX-MP40 MP3/CD player. The CD's work but I can't recieve any radio stations. The seek function cannot locate any stations either. The manual says "Connect a power antenna lead (blue) or accessory power supply lead (red) to the power supply lead of a car's antenna booster." I dunno if that applies to me cause it says it's "Only when you car had built-in FM/AM antenna in the rear/side glass". I'm an idoit and I'd like some help if anyone can assist.
Old Jul 24, 2004 | 07:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: Cannot recieve Radio Stations (Cominom)
If you don't have a power ant. you don't need to hook up the blue lead , have you checked to see if the ant. is plugged into the Sony HU , make sure it is plugged in all the way, if it is plugged in, then you have a problem with the Sony.
hope this helps. 94
Old Jul 24, 2004 | 07:18 PM
Cominom's Avatar
Default Re: Cannot recieve Radio Stations (fcm)
It's in all the way , that I made sure of. Is it possible that the car may have a problem with the antenna? Is it possibly fuse related? I dont have a power antenna.
Old Jul 24, 2004 | 08:01 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cominom &raquo;</TD></TR><TR><TD CLASS="quote">It's in all the way , that I made sure of. Is it possible that the car may have a problem with the antenna? Is it possibly fuse related? I dont have a power antenna.</TD></TR></TABLE> Yes it can be a ant. problem ,not a fuse, did it work with the HU you had in there before, I have been installing for 30 years and sometimes even now the ant. will somehow pop out when putting HU into dash.
94
Old Jul 25, 2004 | 05:56 AM
Cominom's Avatar
When you say that the ant can pop out, what do you mean? Is this antenna booster thing applicable?
Old Jul 25, 2004 | 06:42 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cominom &raquo;</TD></TR><TR><TD CLASS="quote">When you say that the ant can pop out, what do you mean? Is this antenna booster thing applicable?</TD></TR></TABLE> No,I mean the ant plug at the back of the HU, if you have already checked that,its not the problem,did the radio work on the HU that was in the car before you put the Sony in? does your car have the ant. built into the rear /side glass, did you use a adpt. harness when you installed the Sony? I need to know so I can help. 94
Old Jul 25, 2004 | 06:45 AM
PSU's Avatar
PSU
formerly DxHatchback
i hate messing with am/fm
i never get a good reception
check for a plug on the end of your oem antenna connector
i know mine broke off and i didnt get any reception
Old Jul 25, 2004 | 07:14 AM
Cominom's Avatar
The radio did work before I put the Sony in. I know the antenna is built in, but I'm not sure if it's in the rear/side glass. I had to use a wire harness when I put the sony in. I know the antenna coming from the car is plugged in firmly to the Sony Unit, but I dont know where that lead comes from.
Old Jul 25, 2004 | 09:15 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cominom &raquo;</TD></TR><TR><TD CLASS="quote">The radio did work before I put the Sony in. I know the antenna is built in, but I'm not sure if it's in the rear/side glass. I had to use a wire harness when I put the sony in. I know the antenna coming from the car is plugged in firmly to the Sony Unit, but I dont know where that lead comes from.
</TD></TR></TABLE> On the wireing harness you used to plud into the oem radio harness was there a blue wire, I have never seen a Honda with an amped ant. VWs yes but not Hondas, may differant in the USA , if there is a blue wire on the adpt. harness, hook up the blue wire from the Sony to it ,it can't hurt, also,[may be a pain] but plug in the old HU, and if radio works, then for sure you have a problem with the Sony. 94
Old Jul 25, 2004 | 08:15 PM
Cominom's Avatar
I was afraid of that... is there some sort of an adapter that I'm missing? I dunno I'm just really frustrated. Thanks guys.
Old Jul 25, 2004 | 08:58 PM
audioroach's Avatar
If you used an adaptor harness...connect the blue wire ( antenna turn
on to the radios blue power antenna lead. Your car does have an
amplified antenna....its located in the rear glass...the booster is
behind the passenger trim panel near the rear glass. Do this and you will
get recption again.
Old Jul 25, 2004 | 09:29 PM
Cominom's Avatar
Default Re: Cannot recieve Radio Stations (audioroach)
So ur telling me all I have to do is connect the blue wires, but I tried that and it still didn't work... ? Like I said I'm an idoit and I have NO experience with cars (which would have helped).
Old Jul 26, 2004 | 03:44 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cominom &raquo;</TD></TR><TR><TD CLASS="quote">So ur telling me all I have to do is connect the blue wires, but I tried that and it still didn't work... ? Like I said I'm an idoit and I have NO experience with cars (which would have helped). </TD></TR></TABLE> Was it the blue wire on the harness from the Sony HU, to the blue wire on the adpt. harness that you plug into the cars radio harness, [ that is the adpt. that I am talking about] it is the harness that you don't get with the Sony HU, but has all the same colored wires on it to match up to the harness you do get with the Sony HU. The Sony harness plugs into the Sony HU, the other [adpt.] harness plugs into the car.
The Sony harness may have 2 blue wires, one is blue, the other is blue with a white stripe on it, DO NOT CONNECT THEM TOGETHER
hope this helps. 94
FilipinoChino
Honda CR-V & Element
Apr 21, 2014 01:48 PM
dlprince
Audio / Security / Video
Jun 3, 2008 03:44 PM
goheel
Sep 3, 2007 09:48 PM
TB123
May 9, 2007 01:17 PM
That'll Leave A Mark
Dec 5, 2003 08:30 PM
