Can this circuit board be saved?
Old May 28, 2008 | 04:49 PM
fireant's Avatar
Default Can this circuit board be saved?
I know all the bad solders can be fixed, and I can replace the capacitors on the other side of them if needed, but what about the scorched coating (where its black over the copper)?
Old May 28, 2008 | 05:10 PM
B18C_EJ8's Avatar
Damn!! How'd you do that???
I dunno man.... I would imagine that if you soldered in the appropriate sized jumpers and eliminated those burnt sections, maybe you could save that, but it's gonna take some time...
What is this thing?
Old May 28, 2008 | 07:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: Can this circuit board be saved? (fireant)
That's a lot of burnt trace and it looks like there are 3 - 4 pins on the chip that got very hot, I'd put money on the chip being toast. 94
Old May 28, 2008 | 10:12 PM
nsxxtreme's Avatar
Can it be fixed?
Yes, Just follow the trace and use an appropriate size wire between the solder joints.
use some 99% alcohol and an acid brush trimmed to 1/2" to clean the board up. Don't use the cheap 70% alcohol crap its to watered down.
Old May 29, 2008 | 04:27 AM
fireant's Avatar
Default Re: (nsxxtreme)
Yeah, I replaced it with a unit from the junk yard. I dont really know what happened to it. It came that way. It is the ICU for wipers/turn signals on a crx.
sup3rd
Lighting
11
Jun 25, 2008 04:44 PM
96supercharged
Welding / Fabrication
36
Jan 23, 2008 02:17 PM
RACEPAK
Dec 2, 2004 02:00 PM
xdjoynerx
Aug 8, 2004 10:36 PM
slvrcivic97
Nov 4, 2002 07:56 PM
