Calculate wattage output
Old Dec 19, 2008 | 09:17 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Calculate wattage output
A few thing first:
- This is not related to car audio. I'm asking it here because I think there are more expert here on this type of question.
- I know there are so many other factors. And the true test is with the ears.
- This is actually for home audio
So here goes. I'll use round off examples to make things easier.
Set up A - Currently running two 10w speakers. No sub.
Set up B - I'm replacing them with two 5w speakers and 10w sub.
10+10=20. 5+5+10=20
Is there a formula that I can calculate the sound output to find out if A will equal to B?
Or if I want to go 2x or 3X more powerful, what combo of speakers and sub should I go with?
Or there is no such formula/calculation that would provide a general answer.
TIA
Old Dec 19, 2008 | 09:27 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Problem here there is no wattage output here. Need more infomation. ohm of the speakers, amp output
Old Dec 19, 2008 | 09:32 AM
GoLowDrew's Avatar
Old Member
25 Year Member
No ohm available on the speakers. Or amp output. The sub is "powered" by it's own internal source.
The speakers wattage "10 W" is all that is given. I assume that means output?
Old Dec 19, 2008 | 10:08 AM
It Wasn't Me's Avatar
That "10 W" on the speakers are it's input capability. Which is very little.
What brand is this stuff? Got any model numbers? Pictures?
Old Dec 19, 2008 | 10:32 AM
Can't help with out the info needed. :shrugs:
Old Dec 19, 2008 | 03:50 PM
mrdeadman's Avatar
They let me pick
If the sub has it's own power supply then why would it matter what speakers you run? You can measure the resistance of the speakers by using an ohm meter. You could potentially fry the 5w speakers if you connect them to a power source that outputs more.
Old Dec 19, 2008 | 03:55 PM
mrdeadman's Avatar
They let me pick
The 5w speakers could potentially fry if you put too much power to them.
bopbop93030
Audio / Security / Video
15
May 3, 2009 08:16 PM
Civic Si Kid
Feb 28, 2009 07:42 PM
Cody2289
14
Feb 11, 2008 09:28 AM
Odessa
Jul 11, 2004 08:48 AM
Bubble Gum Jr.
Jan 26, 2003 09:32 AM
