building a subwoofer enclosure
Old Mar 12, 2005 | 12:24 AM
idriveadelsol7's Avatar
Default building a subwoofer enclosure
i went to the store today and saw the enclosures they give away with the 12" jL audio W7... this thing doesn't look like it will fit into the trunk of a del sol because of its' height. i have all the materials. just need specs to work with... or somewhere i can buy a box that will fit. thank you
Old Mar 12, 2005 | 07:45 AM
jdMaDDiCT666's Avatar
Default Re: building a subwoofer enclosure (hondaTheSun)
FIND THE SPECS OF THE SPEAKER ON JLAUDIO AND IM SURE FROM THAT YOU CAN BUILD A BOX THAT WILL FIT UR CAR IT WILL TELL YOU THE MINIUM SIZE THAT YOU CAN BUILD THAT BOX....GO OIN THE WEBSITE AND BUILD IT TO TRUNK SIZE AND SEE IF IT WORKS OUT ......
Old Mar 12, 2005 | 10:41 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaTheSun &raquo;</TD></TR><TR><TD CLASS="quote">i went to the store today and saw the enclosures they give away with the 12" jL audio W7... this thing doesn't look like it will fit into the trunk of a del sol because of its' height. i have all the materials. just need specs to work with... or somewhere i can buy a box that will fit. thank you</TD></TR></TABLE> Go to http://www.jlaudio.com all the help you need 94
Old Mar 13, 2005 | 01:33 AM
Default Re: building a subwoofer enclosure (fcm)
i want something to fit in the trunk of a deL soL. i'm afraid i'm going to mess up and that 12" jL w7 won't sound it's best.
Old Mar 13, 2005 | 03:46 AM
ballplayer's Avatar
Default Re: building a subwoofer enclosure (deLsoL7)
just look up the specs from the site like they already said, and just make sure that when you build the box, it has the recomended airspace for that speaker. I believe The W7's require a **** load of airspace, and if your not sure on how to figure it out, you can go to http://www.the12volt.com under the "volume calculator" section. All you do is type in the thickness, height, and width of the box in order to find out the interior airspace for that specific box. Good luck with it, and let us know how it comes out!
Old Mar 13, 2005 | 08:49 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deLsoL7 &raquo;</TD></TR><TR><TD CLASS="quote">i want something to fit in the trunk of a deL soL. i'm afraid i'm going to mess up and that 12" jL w7 won't sound it's best.</TD></TR></TABLE>You may have to go with fiberglass to get the room you need, not hard to do, messy , and will take some time, but may be the only way. If you search, you can find lots of good sites on fiberglasing. 94
Apocolipse269
Audio / Security / Video
Nov 4, 2005 05:30 PM
i be wood
Dec 16, 2004 02:59 AM
s2kds
Dec 18, 2003 06:47 PM
racingsol
Dec 7, 2002 10:54 AM
Chavez
Sep 16, 2001 10:21 PM
